Then perhaps you can go a second dirty way.
You can create Scenes, associate each scene with the trap event switch, and the you can choose the scene in if-then.
Hope it helps
Trap events functionality lost after upgrade
Re: Trap events functionality lost after upgrade
How do I associate a scene with a trap event?
When I try to add a switch to the scene, I can only select my wall plug switch, not the trap event switches. However I can see my switches (form my wall controller) on my dashboard - those are the 'trap event switches', right?
The same. In Scene App, the remote buttons are not available in the switch list when trying to add a switch even if the remote buttons are visible in the "elements" page....
Nick
Raspberry + Razberry + FGS221 x 4 + FGRM 222 + Aeon Labs Micro Motor Controller + FGK 101 + Z-Wave Aeotec Smart Plug-in Switch GEN5 + Minimote + Aeotec KeyFob + Greenwave Smart Power Node x 2
ok, then try switchcontrolgeneratorapp (first) or multisensor
Dear Christian,
I didn't find any app named "switchcontrolgenerator" and also I didn't find how to use multisensor in order to solve the problem ...
fpnick did you manage to find the the solution ?
Nick
sorry thats the id, name ist trap events from remotes and sensors and you already use it.
No, but I didn't find time to look into this during the last couple of days.nic_rt wrote:fpnick did you manage to find the the solution ?
I'm thinking we're missing something stupid here. There must be other people toggling scenes using switches, right?!
Just to let you know, I went back to the v2.1.1 in order to recover the remotes as I use them a lot. It works like this
. Please let us know if you have an idea about that issue.
Is this a bug in the new version ? If yes, will it be corrected ? Or is it due to our specific configuration ?
If I can help to this, I will be pleased to do it.
Nick
