Yale Real Living lock not reporting status
mikemaat
Post by mikemaat »
I am using a Razberry and have successfully added all my Z-Wave devices to Z-Way Server. However, my Yale Real Living touchscreen door lock is not reporting it's status. When I run http://192.168.0.1:8083/ZAutomation/api/v1/devices, the door lock shows a level of "". From my understanding this should show "open" or "close".
Any ideas why it wouldn't be reporting or what i can try?
Here is my devices listing:
{"data":{"structureChanged":true,"updateTime":1489725800,"devices":[{"creationTime":1489641429,"creatorId":5,"customIcons":{},"deviceType":"text","h":-1261400328,"hasHistory":false,"id":"InfoWidget_5_Int","location":0,"metrics":{"title":"Dear Expert User","text":"<center>If you still want to use ExpertUI please go, after you are successfully logged in, to <br><strong> Menu > Devices > Manage with ExpertUI </strong> <br> or call <br><strong> http://MYRASP:8083/expert </strong><br> in your browser. <br> <br>You could hide or remove this widget in menu <br><strong>Apps > Active Tab</strong>. </center>","icon":"app/img/logo-z-wave-z-only.png"},"permanently_hidden":false,"probeType":"","tags":["Homebridge.Skip"],"visibility":true,"updateTime":1489649971},{"creationTime":1489641428,"creatorId":7,"customIcons":{},"deviceType":"battery","h":-592588978,"hasHistory":false,"id":"BatteryPolling_7","location":0,"metrics":{"probeTitle":"Battery","scaleTitle":"%","title":"Battery digest 7","level":48},"permanently_hidden":false,"probeType":"","tags":[],"visibility":true,"updateTime":1489725270},{"creationTime":1489644587,"creatorId":1,"customIcons":{},"deviceType":"switchMultilevel","h":1078449916,"hasHistory":false,"id":"ZWayVDev_zway_2-0-38","location":0,"metrics":{"icon":"multilevel","title":"Foyer Dimmer","level":0},"permanently_hidden":false,"probeType":"multilevel","tags":[],"visibility":true,"updateTime":1489725217},{"creationTime":1489644597,"creatorId":1,"customIcons":{},"deviceType":"switchBinary","h":1107079066,"hasHistory":false,"id":"ZWayVDev_zway_3-0-37","location":0,"metrics":{"icon":"switch","title":"Outside Front Lights","level":"on"},"permanently_hidden":false,"probeType":"","tags":[],"visibility":true,"updateTime":1489649972},{"creationTime":1489644636,"creatorId":1,"customIcons":{},"deviceType":"switchBinary","h":1164337368,"hasHistory":false,"id":"ZWayVDev_zway_5-0-37","location":0,"metrics":{"icon":"switch","title":"Garage Light","level":"off"},"permanently_hidden":false,"probeType":"","tags":[],"visibility":true,"updateTime":1489651896},{"creationTime":1489644660,"creatorId":1,"customIcons":{},"deviceType":"switchBinary","h":1192966519,"hasHistory":false,"id":"ZWayVDev_zway_6-0-37","location":0,"metrics":{"icon":"switch","title":"Bonus Room Light","level":"off"},"permanently_hidden":false,"probeType":"","tags":[],"visibility":true,"updateTime":1489725227},{"creationTime":1489644626,"creatorId":1,"customIcons":{},"deviceType":"battery","h":847214338,"hasHistory":false,"id":"ZWayVDev_zway_4-0-128","location":0,"metrics":{"probeTitle":"Battery","scaleTitle":"%","level":48,"icon":"battery","title":"Vision Security Battery (#4)"},"permanently_hidden":false,"probeType":"","tags":[],"visibility":true,"updateTime":1489725270},{"creationTime":1489644627,"creatorId":1,"customIcons":{},"deviceType":"doorlock","h":1135708404,"hasHistory":false,"id":"ZWayVDev_zway_4-0-98","location":0,"metrics":{"level":"","icon":"door","title":"Front Door Lock"},"permanently_hidden":false,"probeType":"","tags":[],"visibility":true,"updateTime":1489725439}]},"code":200,"message":"200 OK","error":null}
Re: Yale Real Living lock not reporting status
We need the log when status changes.
mikemaat
Post by mikemaat »
Here is the log showing a lock and unlock
[2017-03-19 20:22:18.007] [D] [zway] RECEIVED: ( 01 07 00 13 06 00 00 8F 62 )
[2017-03-19 20:22:18.007] [D] [zway] SENT ACK
[2017-03-19 20:22:18.007] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2017-03-19 20:22:18.008] [D] [zway] SendData Response with callback 0x06 received: received by recipient
[2017-03-19 20:22:18.008] [D] [zway] SETDATA devices.4.data.lastSend = 22543 (0x0000580f)
[2017-03-19 20:22:18.008] [D] [zway] Job 0x13 (Nonce Get): success
[2017-03-19 20:22:18.008] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-03-19 20:22:18.008] [D] [zway] SETDATA devices.4.data.lastNonceGet = 22543 (0x0000580f)
[2017-03-19 20:22:18.008] [I] [zway] Removing job: Nonce Get
[2017-03-19 20:22:18.058] [D] [zway] RECEIVED: ( 01 10 00 04 00 04 0A 98 80 62 63 84 2E CA D8 1B 2F 70 )
[2017-03-19 20:22:18.059] [D] [zway] SENT ACK
[2017-03-19 20:22:18.059] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2017-03-19 20:22:18.059] [I] [zway] Node 4:0 CC Security: received Nonce Report
[2017-03-19 20:22:18.059] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonce = **********
[2017-03-19 20:22:18.059] [I] [zway] Node 4:0 CC Security: Sending a secure message
[2017-03-19 20:22:18.059] [I] [zway] Node 4:0 CC Security: sending encrypted packet: Door Lock Operation Set
[2017-03-19 20:22:18.059] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.toFollow = False
[2017-03-19 20:22:18.059] [D] [zway] SETDATA devices.4.data.lastNonceGet = Empty
[2017-03-19 20:22:18.060] [I] [zway] Adding job: Security, Door Lock Operation Set
[2017-03-19 20:22:18.060] [I] [zway] Node 4:0 CC Security: sending Nonce Get
[2017-03-19 20:22:18.060] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-03-19 20:22:18.060] [I] [zway] Adding job: Nonce Get
[2017-03-19 20:22:18.060] [D] [zway] SETDATA devices.4.data.lastNonceGet = 22548 (0x00005814)
[2017-03-19 20:22:18.078] [D] [zway] SENDING (cb 0x07): ( 01 1E 00 13 04 17 98 81 B4 E1 23 1D 98 17 37 FA 85 AD 06 93 62 3F 8E 7F C5 3A 4D 55 A9 05 07 8C )
[2017-03-19 20:22:18.082] [D] [zway] RECEIVED ACK
[2017-03-19 20:22:18.086] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-19 20:22:18.086] [D] [zway] SENT ACK
[2017-03-19 20:22:18.086] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Response received - transfered to encapsulated jobs
[2017-03-19 20:22:18.086] [D] [zway] Delivered to Z-Wave stack
[2017-03-19 20:22:18.179] [D] [zway] RECEIVED: ( 01 07 00 13 07 00 00 09 E5 )
[2017-03-19 20:22:18.179] [D] [zway] SENT ACK
[2017-03-19 20:22:18.179] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Callback received - transfered to encapsulated jobs
[2017-03-19 20:22:18.179] [I] [zway] Job 0x13 (Door Lock Operation Set): Delivered
[2017-03-19 20:22:18.179] [D] [zway] SendData Response with callback 0x07 received: received by recipient
[2017-03-19 20:22:18.179] [D] [zway] Job 0x13 (Door Lock Operation Set): success
[2017-03-19 20:22:18.179] [I] [zway] Removing job: Door Lock Operation Set
[2017-03-19 20:22:18.179] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Delivered
[2017-03-19 20:22:18.180] [D] [zway] SendData Response with callback 0x07 received: received by recipient
[2017-03-19 20:22:18.180] [D] [zway] SETDATA devices.4.data.lastSend = 22560 (0x00005820)
[2017-03-19 20:22:18.180] [D] [zway] Job 0x13 (Security, Door Lock Operation Set): success
[2017-03-19 20:22:18.180] [I] [zway] Removing job: Security, Door Lock Operation Set
[2017-03-19 20:22:18.250] [D] [zway] SENDING (cb 0x08): ( 01 09 00 13 04 02 98 40 05 08 36 )
[2017-03-19 20:22:18.252] [D] [zway] RECEIVED ACK
[2017-03-19 20:22:18.256] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-19 20:22:18.256] [D] [zway] SENT ACK
[2017-03-19 20:22:18.256] [D] [zway] Delivered to Z-Wave stack
[2017-03-19 20:22:18.292] [D] [zway] RECEIVED: ( 01 07 00 13 08 00 00 04 E7 )
[2017-03-19 20:22:18.292] [D] [zway] SENT ACK
[2017-03-19 20:22:18.292] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2017-03-19 20:22:18.292] [D] [zway] SendData Response with callback 0x08 received: received by recipient
[2017-03-19 20:22:18.293] [D] [zway] SETDATA devices.4.data.lastSend = 22571 (0x0000582b)
[2017-03-19 20:22:18.293] [D] [zway] Job 0x13 (Nonce Get): success
[2017-03-19 20:22:18.293] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-03-19 20:22:18.293] [D] [zway] SETDATA devices.4.data.lastNonceGet = 22571 (0x0000582b)
[2017-03-19 20:22:18.293] [I] [zway] Removing job: Nonce Get
[2017-03-19 20:22:18.343] [D] [zway] RECEIVED: ( 01 10 00 04 00 04 0A 98 80 A0 B5 ED 3C BC 53 72 1A BE )
[2017-03-19 20:22:18.345] [D] [zway] SENT ACK
[2017-03-19 20:22:18.346] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2017-03-19 20:22:18.346] [I] [zway] Node 4:0 CC Security: received Nonce Report
[2017-03-19 20:22:18.346] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonce = **********
[2017-03-19 20:22:18.346] [I] [zway] Node 4:0 CC Security: Sending a secure message
[2017-03-19 20:22:18.346] [I] [zway] Node 4:0 CC Security: sending encrypted packet: Door Lock Operation Get
[2017-03-19 20:22:18.346] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.toFollow = False
[2017-03-19 20:22:18.346] [D] [zway] SETDATA devices.4.data.lastNonceGet = Empty
[2017-03-19 20:22:18.346] [I] [zway] Adding job: Security, Door Lock Operation Get
[2017-03-19 20:22:18.363] [D] [zway] SENDING (cb 0x09): ( 01 1D 00 13 04 16 98 81 1A B6 BA 6F DE D0 39 41 53 34 5C A0 A5 EC 60 7C 91 CE 56 B8 05 09 86 )
[2017-03-19 20:22:18.366] [D] [zway] RECEIVED ACK
[2017-03-19 20:22:18.370] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-19 20:22:18.370] [D] [zway] SENT ACK
[2017-03-19 20:22:18.371] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Response received - transfered to encapsulated jobs
[2017-03-19 20:22:18.371] [D] [zway] Delivered to Z-Wave stack
[2017-03-19 20:22:18.454] [D] [zway] RECEIVED: ( 01 07 00 13 09 00 00 08 EA )
[2017-03-19 20:22:18.454] [D] [zway] SENT ACK
[2017-03-19 20:22:18.454] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Callback received - transfered to encapsulated jobs
[2017-03-19 20:22:18.454] [I] [zway] Job 0x13 (Door Lock Operation Get): Delivered
[2017-03-19 20:22:18.454] [D] [zway] SendData Response with callback 0x09 received: received by recipient
[2017-03-19 20:22:18.454] [D] [zway] Job 0x13 (Door Lock Operation Get): success
[2017-03-19 20:22:18.455] [I] [zway] Removing job: Door Lock Operation Get
[2017-03-19 20:22:18.455] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Delivered
[2017-03-19 20:22:18.455] [D] [zway] SendData Response with callback 0x09 received: received by recipient
[2017-03-19 20:22:18.455] [D] [zway] SETDATA devices.4.data.lastSend = 22587 (0x0000583b)
[2017-03-19 20:22:18.455] [D] [zway] Job 0x13 (Security, Door Lock Operation Get): success
[2017-03-19 20:22:18.456] [I] [zway] Removing job: Security, Door Lock Operation Get
[2017-03-19 20:22:18.494] [D] [zway] RECEIVED: ( 01 08 00 04 00 04 02 98 40 2D )
[2017-03-19 20:22:18.494] [D] [zway] SENT ACK
[2017-03-19 20:22:18.495] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2017-03-19 20:22:18.495] [I] [zway] Node 4:0 CC Security: sending Nonce Report
[2017-03-19 20:22:18.495] [I] [zway] Adding job: Nonce Report
[2017-03-19 20:22:18.525] [D] [zway] SENDING (cb 0x0a): ( 01 11 00 13 04 0A 98 80 12 D5 CC 1E 3B 04 BE 15 05 0A 65 )
[2017-03-19 20:22:18.527] [D] [zway] RECEIVED ACK
[2017-03-19 20:22:18.531] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-19 20:22:18.531] [D] [zway] SENT ACK
[2017-03-19 20:22:18.531] [D] [zway] Delivered to Z-Wave stack
[2017-03-19 20:22:18.606] [D] [zway] RECEIVED: ( 01 07 00 13 0A 00 00 07 E6 )
[2017-03-19 20:22:18.606] [D] [zway] SENT ACK
[2017-03-19 20:22:18.606] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2017-03-19 20:22:18.606] [D] [zway] SendData Response with callback 0x0a received: received by recipient
[2017-03-19 20:22:18.606] [D] [zway] SETDATA devices.4.data.lastSend = 22602 (0x0000584a)
[2017-03-19 20:22:18.606] [D] [zway] Job 0x13 (Nonce Report): success
[2017-03-19 20:22:18.607] [I] [zway] Removing job: Nonce Report
[2017-03-19 20:22:18.727] [D] [zway] RECEIVED: ( 01 21 00 04 00 04 1B 98 81 8D DE F9 30 90 6C 76 06 9A 88 A1 13 4B FF 51 62 12 CE 7B 0D B3 52 90 69 EC B3 )
[2017-03-19 20:22:18.727] [D] [zway] SENT ACK
[2017-03-19 20:22:18.727] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2017-03-19 20:22:18.728] [I] [zway] Node 4:0 CC Security: Received a secure message
[2017-03-19 20:22:18.728] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.firstPart = **********
[2017-03-19 20:22:18.728] [I] [zway] Node 4:0 CC Security: passing decrypted packet to application level: [ 62 03 00 00 02 fe fe ]
[2017-03-19 20:22:18.728] [D] [zway] SETDATA devices.4.instances.0.commandClasses.98.data.mode = 0 (0x00000000)
[2017-03-19 20:22:18.728] [D] [zway] SETDATA devices.4.instances.0.commandClasses.98.data.outsideMode = 0 (0x00000000)
[2017-03-19 20:22:18.728] [D] [zway] SETDATA devices.4.instances.0.commandClasses.98.data.insideMode = 0 (0x00000000)
[2017-03-19 20:22:18.729] [D] [zway] SETDATA devices.4.instances.0.commandClasses.98.data.condition = 2 (0x00000002)
[2017-03-19 20:22:18.729] [D] [zway] SETDATA devices.4.instances.0.commandClasses.98.data.lockMinutes = 254 (0x000000fe)
[2017-03-19 20:22:18.729] [D] [zway] SETDATA devices.4.instances.0.commandClasses.98.data.lockSeconds = 254 (0x000000fe)
[2017-03-19 20:22:19.314] [D] [zway] RECEIVED: ( 01 08 00 04 00 04 02 98 40 2D )
[2017-03-19 20:22:19.314] [D] [zway] SENT ACK
[2017-03-19 20:22:19.315] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2017-03-19 20:22:19.315] [I] [zway] Node 4:0 CC Security: sending Nonce Report
[2017-03-19 20:22:19.315] [I] [zway] Adding job: Nonce Report
[2017-03-19 20:22:19.315] [D] [zway] SENDING (cb 0x0b): ( 01 11 00 13 04 0A 98 80 EF E6 25 6F 44 E4 86 49 05 0B C9 )
[2017-03-19 20:22:19.325] [D] [zway] RECEIVED ACK
[2017-03-19 20:22:19.325] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-19 20:22:19.325] [D] [zway] SENT ACK
[2017-03-19 20:22:19.325] [D] [zway] Delivered to Z-Wave stack
[2017-03-19 20:22:19.426] [D] [zway] RECEIVED: ( 01 07 00 13 0B 00 00 0A EA )
[2017-03-19 20:22:19.426] [D] [zway] SENT ACK
[2017-03-19 20:22:19.426] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2017-03-19 20:22:19.426] [D] [zway] SendData Response with callback 0x0b received: received by recipient
[2017-03-19 20:22:19.427] [D] [zway] SETDATA devices.4.data.lastSend = 22683 (0x0000589b)
[2017-03-19 20:22:19.427] [D] [zway] Job 0x13 (Nonce Report): success
[2017-03-19 20:22:19.427] [I] [zway] Removing job: Nonce Report
[2017-03-19 20:22:19.568] [D] [zway] RECEIVED: ( 01 1E 00 04 00 04 18 98 81 67 32 07 17 6E 0D 44 D7 13 9A 7F E8 D7 EF 97 AF D0 59 1B 8F 1D 8E C5 )
[2017-03-19 20:22:19.568] [D] [zway] SENT ACK
[2017-03-19 20:22:19.568] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2017-03-19 20:22:19.569] [I] [zway] Node 4:0 CC Security: Received a secure message
[2017-03-19 20:22:19.569] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.firstPart = **********
[2017-03-19 20:22:19.569] [I] [zway] Node 4:0 CC Security: passing decrypted packet to application level: [ 71 05 18 01 ]
[2017-03-19 20:22:19.569] [D] [zway] SETDATA devices.4.instances.0.commandClasses.113.data.V1event.alarmType = 24 (0x00000018)
[2017-03-19 20:22:19.569] [D] [zway] SETDATA devices.4.instances.0.commandClasses.113.data.V1event.level = 1 (0x00000001)
[2017-03-19 20:22:19.569] [D] [zway] SETDATA devices.4.instances.0.commandClasses.113.data.V1event = Empty
[2017-03-19 20:22:27.987] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:22:28.078] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:22:31.669] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:22:31.771] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:22:38.335] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:22:38.477] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:22:38.487] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:22:38.578] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:22:38.710] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:22:38.720] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:22:38.841] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:22:39.620] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:24:40.931] [I] [core] ---  ZWayVDev_zway_4-0-98 performCommand processing: {"0":"open","1":{}}
[2017-03-19 20:24:40.932] [I] [zway] Adding job: Door Lock Operation Set
[2017-03-19 20:24:40.932] [I] [zway] Adding job: Door Lock Operation Get
[2017-03-19 20:24:40.939] [I] [zway] Node 4:0 CC Security: sending Nonce Get
[2017-03-19 20:24:40.939] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-03-19 20:24:40.939] [I] [zway] Adding job: Nonce Get
[2017-03-19 20:24:40.939] [D] [zway] SETDATA devices.4.data.lastNonceGet = 36682 (0x00008f4a)
[2017-03-19 20:24:40.949] [D] [zway] SENDING (cb 0x0c): ( 01 09 00 13 04 02 98 40 05 0C 32 )
[2017-03-19 20:24:40.951] [D] [zway] RECEIVED ACK
[2017-03-19 20:24:40.955] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-19 20:24:40.955] [D] [zway] SENT ACK
[2017-03-19 20:24:40.955] [D] [zway] Delivered to Z-Wave stack
[2017-03-19 20:24:42.335] [D] [zway] RECEIVED: ( 01 07 00 13 0C 00 00 8A 6D )
[2017-03-19 20:24:42.335] [D] [zway] SENT ACK
[2017-03-19 20:24:42.335] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2017-03-19 20:24:42.335] [D] [zway] SendData Response with callback 0x0c received: received by recipient
[2017-03-19 20:24:42.335] [D] [zway] SETDATA devices.4.data.lastSend = 36821 (0x00008fd5)
[2017-03-19 20:24:42.336] [D] [zway] Job 0x13 (Nonce Get): success
[2017-03-19 20:24:42.336] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-03-19 20:24:42.336] [D] [zway] SETDATA devices.4.data.lastNonceGet = 36821 (0x00008fd5)
[2017-03-19 20:24:42.336] [I] [zway] Removing job: Nonce Get
[2017-03-19 20:24:42.386] [D] [zway] RECEIVED: ( 01 10 00 04 00 04 0A 98 80 04 AB CB EC 52 8A 8F F6 D4 )
[2017-03-19 20:24:42.387] [D] [zway] SENT ACK
[2017-03-19 20:24:42.387] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2017-03-19 20:24:42.387] [I] [zway] Node 4:0 CC Security: received Nonce Report
[2017-03-19 20:24:42.387] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonce = **********
[2017-03-19 20:24:42.387] [I] [zway] Node 4:0 CC Security: Sending a secure message
[2017-03-19 20:24:42.387] [I] [zway] Node 4:0 CC Security: sending encrypted packet: Door Lock Operation Set
[2017-03-19 20:24:42.387] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.toFollow = False
[2017-03-19 20:24:42.387] [D] [zway] SETDATA devices.4.data.lastNonceGet = Empty
[2017-03-19 20:24:42.387] [I] [zway] Adding job: Security, Door Lock Operation Set
[2017-03-19 20:24:42.388] [I] [zway] Node 4:0 CC Security: sending Nonce Get
[2017-03-19 20:24:42.388] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-03-19 20:24:42.388] [I] [zway] Adding job: Nonce Get
[2017-03-19 20:24:42.388] [D] [zway] SETDATA devices.4.data.lastNonceGet = 36826 (0x00008fda)
[2017-03-19 20:24:42.406] [D] [zway] SENDING (cb 0x0d): ( 01 1E 00 13 04 17 98 81 86 58 87 5E 55 F8 28 92 C6 16 66 0F 04 95 2B 43 8F D1 63 6A DF 05 0D 28 )
[2017-03-19 20:24:42.410] [D] [zway] RECEIVED ACK
[2017-03-19 20:24:42.414] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-19 20:24:42.414] [D] [zway] SENT ACK
[2017-03-19 20:24:42.414] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Response received - transfered to encapsulated jobs
[2017-03-19 20:24:42.414] [D] [zway] Delivered to Z-Wave stack
[2017-03-19 20:24:42.507] [D] [zway] RECEIVED: ( 01 07 00 13 0D 00 00 09 EF )
[2017-03-19 20:24:42.507] [D] [zway] SENT ACK
[2017-03-19 20:24:42.507] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Callback received - transfered to encapsulated jobs
[2017-03-19 20:24:42.508] [I] [zway] Job 0x13 (Door Lock Operation Set): Delivered
[2017-03-19 20:24:42.508] [D] [zway] SendData Response with callback 0x0d received: received by recipient
[2017-03-19 20:24:42.508] [D] [zway] Job 0x13 (Door Lock Operation Set): success
[2017-03-19 20:24:42.508] [I] [zway] Removing job: Door Lock Operation Set
[2017-03-19 20:24:42.508] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Delivered
[2017-03-19 20:24:42.508] [D] [zway] SETDATA devices.4.data.lastSend = 36838 (0x00008fe6)
[2017-03-19 20:24:42.508] [D] [zway] Job 0x13 (Security, Door Lock Operation Set): success
[2017-03-19 20:24:42.508] [I] [zway] Removing job: Security, Door Lock Operation Set
[2017-03-19 20:24:42.577] [D] [zway] SENDING (cb 0x0e): ( 01 09 00 13 04 02 98 40 05 0E 30 )
[2017-03-19 20:24:42.579] [D] [zway] RECEIVED ACK
[2017-03-19 20:24:42.583] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-19 20:24:42.583] [D] [zway] SENT ACK
[2017-03-19 20:24:42.583] [D] [zway] Delivered to Z-Wave stack
[2017-03-19 20:24:42.628] [D] [zway] RECEIVED: ( 01 07 00 13 0E 00 00 04 E1 )
[2017-03-19 20:24:42.628] [D] [zway] SENT ACK
[2017-03-19 20:24:42.628] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2017-03-19 20:24:42.629] [D] [zway] SendData Response with callback 0x0e received: received by recipient
[2017-03-19 20:24:42.629] [D] [zway] SETDATA devices.4.data.lastSend = 36850 (0x00008ff2)
[2017-03-19 20:24:42.629] [D] [zway] Job 0x13 (Nonce Get): success
[2017-03-19 20:24:42.629] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-03-19 20:24:42.629] [D] [zway] SETDATA devices.4.data.lastNonceGet = 36850 (0x00008ff2)
[2017-03-19 20:24:42.629] [I] [zway] Removing job: Nonce Get
[2017-03-19 20:24:42.669] [D] [zway] RECEIVED: ( 01 10 00 04 00 04 0A 98 80 EB AA B6 B4 0A E8 30 E4 88 )
[2017-03-19 20:24:42.669] [D] [zway] SENT ACK
[2017-03-19 20:24:42.670] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2017-03-19 20:24:42.670] [I] [zway] Node 4:0 CC Security: received Nonce Report
[2017-03-19 20:24:42.670] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonce = **********
[2017-03-19 20:24:42.670] [I] [zway] Node 4:0 CC Security: Sending a secure message
[2017-03-19 20:24:42.670] [I] [zway] Node 4:0 CC Security: sending encrypted packet: Door Lock Operation Get
[2017-03-19 20:24:42.670] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.toFollow = False
[2017-03-19 20:24:42.671] [D] [zway] SETDATA devices.4.data.lastNonceGet = Empty
[2017-03-19 20:24:42.671] [I] [zway] Adding job: Security, Door Lock Operation Get
[2017-03-19 20:24:42.699] [D] [zway] SENDING (cb 0x0f): ( 01 1D 00 13 04 16 98 81 71 05 79 C6 78 23 A9 55 65 E2 EA EB 17 DE FF 8A 00 25 B3 3E 05 0F 0E )
[2017-03-19 20:24:42.703] [D] [zway] RECEIVED ACK
[2017-03-19 20:24:42.707] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-19 20:24:42.707] [D] [zway] SENT ACK
[2017-03-19 20:24:42.707] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Response received - transfered to encapsulated jobs
[2017-03-19 20:24:42.707] [D] [zway] Delivered to Z-Wave stack
[2017-03-19 20:24:42.781] [D] [zway] RECEIVED: ( 01 07 00 13 0F 00 00 08 EC )
[2017-03-19 20:24:42.781] [D] [zway] SENT ACK
[2017-03-19 20:24:42.781] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Callback received - transfered to encapsulated jobs
[2017-03-19 20:24:42.781] [I] [zway] Job 0x13 (Door Lock Operation Get): Delivered
[2017-03-19 20:24:42.781] [D] [zway] SendData Response with callback 0x0f received: received by recipient
[2017-03-19 20:24:42.781] [D] [zway] Job 0x13 (Door Lock Operation Get): success
[2017-03-19 20:24:42.782] [I] [zway] Removing job: Door Lock Operation Get
[2017-03-19 20:24:42.782] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Delivered
[2017-03-19 20:24:42.782] [D] [zway] SendData Response with callback 0x0f received: received by recipient
[2017-03-19 20:24:42.782] [D] [zway] SETDATA devices.4.data.lastSend = 36865 (0x00009001)
[2017-03-19 20:24:42.782] [D] [zway] Job 0x13 (Security, Door Lock Operation Get): success
[2017-03-19 20:24:42.782] [I] [zway] Removing job: Security, Door Lock Operation Get
[2017-03-19 20:24:42.832] [D] [zway] RECEIVED: ( 01 08 00 04 00 04 02 98 40 2D )
[2017-03-19 20:24:42.833] [D] [zway] SENT ACK
[2017-03-19 20:24:42.833] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2017-03-19 20:24:42.833] [I] [zway] Node 4:0 CC Security: sending Nonce Report
[2017-03-19 20:24:42.833] [I] [zway] Adding job: Nonce Report
[2017-03-19 20:24:42.853] [D] [zway] SENDING (cb 0x10): ( 01 11 00 13 04 0A 98 80 F4 0E C2 85 2A 31 45 F3 05 10 EE )
[2017-03-19 20:24:42.855] [D] [zway] RECEIVED ACK
[2017-03-19 20:24:42.859] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-19 20:24:42.859] [D] [zway] SENT ACK
[2017-03-19 20:24:42.859] [D] [zway] Delivered to Z-Wave stack
[2017-03-19 20:24:42.935] [D] [zway] RECEIVED: ( 01 07 00 13 10 00 00 07 FC )
[2017-03-19 20:24:42.935] [D] [zway] SENT ACK
[2017-03-19 20:24:42.935] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2017-03-19 20:24:42.935] [D] [zway] SendData Response with callback 0x10 received: received by recipient
[2017-03-19 20:24:42.935] [D] [zway] SETDATA devices.4.data.lastSend = 36880 (0x00009010)
[2017-03-19 20:24:42.935] [D] [zway] Job 0x13 (Nonce Report): success
[2017-03-19 20:24:42.936] [I] [zway] Removing job: Nonce Report
[2017-03-19 20:24:43.065] [D] [zway] RECEIVED: ( 01 21 00 04 00 04 1B 98 81 F7 A6 1F C2 AC 1B E9 2F DE F3 19 EF AA 3B 62 4D F4 8C CE 99 E9 22 C6 6F 5A 53 )
[2017-03-19 20:24:43.065] [D] [zway] SENT ACK
[2017-03-19 20:24:43.065] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2017-03-19 20:24:43.065] [I] [zway] Node 4:0 CC Security: Received a secure message
[2017-03-19 20:24:43.066] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.firstPart = **********
[2017-03-19 20:24:43.066] [I] [zway] Node 4:0 CC Security: passing decrypted packet to application level: [ 62 03 ff 00 00 fe fe ]
[2017-03-19 20:24:43.066] [D] [zway] SETDATA devices.4.instances.0.commandClasses.98.data.mode = 255 (0x000000ff)
[2017-03-19 20:24:43.066] [D] [zway] SETDATA devices.4.instances.0.commandClasses.98.data.outsideMode = 0 (0x00000000)
[2017-03-19 20:24:43.066] [D] [zway] SETDATA devices.4.instances.0.commandClasses.98.data.insideMode = 0 (0x00000000)
[2017-03-19 20:24:43.066] [D] [zway] SETDATA devices.4.instances.0.commandClasses.98.data.condition = 0 (0x00000000)
[2017-03-19 20:24:43.066] [D] [zway] SETDATA devices.4.instances.0.commandClasses.98.data.lockMinutes = 254 (0x000000fe)
[2017-03-19 20:24:43.066] [D] [zway] SETDATA devices.4.instances.0.commandClasses.98.data.lockSeconds = 254 (0x000000fe)
[2017-03-19 20:24:43.641] [D] [zway] RECEIVED: ( 01 08 00 04 00 04 02 98 40 2D )
[2017-03-19 20:24:43.641] [D] [zway] SENT ACK
[2017-03-19 20:24:43.641] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2017-03-19 20:24:43.642] [I] [zway] Node 4:0 CC Security: sending Nonce Report
[2017-03-19 20:24:43.642] [I] [zway] Adding job: Nonce Report
[2017-03-19 20:24:43.642] [D] [zway] SENDING (cb 0x11): ( 01 11 00 13 04 0A 98 80 AB CE 7C 5D 97 BD B5 46 05 11 62 )
[2017-03-19 20:24:43.651] [D] [zway] RECEIVED ACK
[2017-03-19 20:24:43.651] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-03-19 20:24:43.651] [D] [zway] SENT ACK
[2017-03-19 20:24:43.652] [D] [zway] Delivered to Z-Wave stack
[2017-03-19 20:24:43.752] [D] [zway] RECEIVED: ( 01 07 00 13 11 00 00 0A F0 )
[2017-03-19 20:24:43.752] [D] [zway] SENT ACK
[2017-03-19 20:24:43.752] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2017-03-19 20:24:43.752] [D] [zway] SendData Response with callback 0x11 received: received by recipient
[2017-03-19 20:24:43.752] [D] [zway] SETDATA devices.4.data.lastSend = 36961 (0x00009061)
[2017-03-19 20:24:43.752] [D] [zway] Job 0x13 (Nonce Report): success
[2017-03-19 20:24:43.752] [I] [zway] Removing job: Nonce Report
[2017-03-19 20:24:43.893] [D] [zway] RECEIVED: ( 01 1E 00 04 00 04 18 98 81 88 AB 2A 4C AE BC C5 C8 2D A0 94 DB D0 AB C3 F2 D5 D7 9B 0B 06 AF 09 )
[2017-03-19 20:24:43.893] [D] [zway] SENT ACK
[2017-03-19 20:24:43.894] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2017-03-19 20:24:43.894] [I] [zway] Node 4:0 CC Security: Received a secure message
[2017-03-19 20:24:43.894] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.firstPart = **********
[2017-03-19 20:24:43.894] [I] [zway] Node 4:0 CC Security: passing decrypted packet to application level: [ 71 05 19 01 ]
[2017-03-19 20:24:43.894] [D] [zway] SETDATA devices.4.instances.0.commandClasses.113.data.V1event.alarmType = 25 (0x00000019)
[2017-03-19 20:24:43.894] [D] [zway] SETDATA devices.4.instances.0.commandClasses.113.data.V1event.level = 1 (0x00000001)
[2017-03-19 20:24:43.895] [D] [zway] SETDATA devices.4.instances.0.commandClasses.113.data.V1event = Empty
[2017-03-19 20:25:02.715] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:25:02.848] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:25:02.859] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:25:02.950] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:25:03.081] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:25:03.092] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:25:03.203] [D] [zway] Job 0x13: deleted from queue
[2017-03-19 20:25:03.961] [D] [zway] Job 0x13: deleted from queue
mikemaat
Post by mikemaat »
Bump. Any ideas?
mikemaat
Post by mikemaat »
I downgraded to 2.2.5 and it seems to be working now. The issue seems to be in 2.3.0.
Please test this patch:
+++ modules/ZWave/index.js
@@ -4214,7 +4214,7 @@ ZWave.prototype.parseAddCommandClass = function (nodeId, instanceId, commandClas
                                moduleId: self.id
                        if (vDev) {
-                               self.dataBind(self.gateDataBinding, self.zway, nodeId, instanceId, commandClassId, "mode", function() {
+                               self.dataBind(self.gateDataBinding, self.zway, nodeId, instanceId, commandClassId, "mode", function(type) {
                                        try {
                                                if (!(type & self.ZWAY_DATA_CHANGE_TYPE["Invalidated"])) {
                                                        vDev.set("metrics:level", this.value === 255 ? "close" : "open");
It should work then. Please confirm.
