control for Heating/Temperature/Time
cobra
Post by cobra »
Hello Community!
I need your Help how i can realise this Control,
Used Parts:
Temperature Sensor Philio 4in1
Switch Wall Plug Fibaro
At 6am the Temperatur shall be promted and if it is not 25 Degrees the Wall plug shall be turned on for max 30 minutes or temp reaches 27 degrees.
Thanks for your Help,
lg
Martin
Smarthome Pi3 with Zwave Modul und Control with zwave me.
silverhack
Re: control for Heating/Temperature/Time
Post by silverhack »
You could add 3 app devices:
1) Condition Switch to turn the device on at 6:00 if temp is < 25
2) If-> Then app to turn the device off if temp is >26
3) Automated Switch Off to turn the device off if it has been on for 30 minutes.
See screenshots for examples.
Sharppis
Post by Sharppis »
this looks pretty much what I'm looking for, but is there chance to use Virtual temperature sensor instead of hardware sensor?
