hi
I am beginnger with z-wave and installed Z-way on raspberry Pi 3 with razberry card
but i have error
An unexpected error occurred while initialising the Z-Wave controller data.
Please check
1.) if the controller is plugged in correctly,
2.) that in the app 'Z-Wave Network Access' the right port is entered
(UZB: '/dev/ttyACM0', Box: '/dev/ttyAMA0', UZB-Windows: '\\\\.\\COM3', Z-Stick: '/dev/ttyUSB0', embedded boxes: '/dev/ttyS0' or '/dev/ttyS1')
3.) the app is aktiv. If not you could activate it under Menu > Apps > Activ or add a new one under Menu > Apps > Local.
The Setting 'Expert View' needs to be active under Menu > My Settings
on my raspberry in find /dev/ttyAMA0 b
and the time in my zway is incorrect how to chage it
thanks for help
razberry on raspberry pi 3
- Untitled3.png (108.47 KiB) Viewed 10155 times
- z-wave ACM0.png (154.13 KiB) Viewed 10157 times
- Untitled2.png (100.58 KiB) Viewed 10157 times
- Untitled.png (629.45 KiB) Viewed 10157 times
- Z-Wave Support
Re: razberry on raspberry pi 3
How do you have install the zway software and have you deactivate Bluetooth?
Is the red LED on Razberry on or off?
The Time you must set in your raspberry pi.
Best regards
Z-Wave Support
Best regards
Z-Wave Support
hi youZ-Wave Support wrote: ↑16 Aug 2017 15:50Hello,
Best regards
Z-Wave Support
I install z-way with razberry.img.zip that i downlload
but i did deactivate Bluetooth yet,
so how deactivate Bluetooth?
thanks you
- Z-Wave Support
Bluetooth and razberry using the same Port.
The simplest variant is install the Z-Way software with command
on your pi, then will deactivate this automatically.
Best regards
Z-Wave Support
Best regards
Z-Wave Support
thanks for your help
I will try again installing with wget -q -O - razberry.z-wave.me/install | sudo bash
