Fortrez MIMO2+ interview
kpanchen
Post by kpanchen »
I have a problem with interview on Fortrez MIMO2+ device, interview basically stuck on 93% and two items never finished. If I go and Force to do interview manually it seems like controller is not doing anything at all, I don't see any activity in the Queue or in the log.
Device basically has 5 instances, 1 generic, 2 sensors and 2 relays, the problem is with the last to relays which cannot finish Association Group Information (0x59/89) interview, which actually supposed to be only one group "Lifeline".
Force Interview.png (9.69 KiB) Viewed 10929 times
At the same time from Expert Commands I can get all the required information, no failures and I see activity in the log.
Command Class.png (17.93 KiB) Viewed 10929 times
I've attached relevant log as well, from the log I see the whole interview goes fine, reaching the end and doing the last two items but unfortunately cannot tell why it is not finishing them.
Any help greatly appreciated!!
z-way-server_ex.zip
(1.29 KiB) Downloaded 687 times
kpanchen
Re: Fortrez MIMO2+ interview
Post by kpanchen »
Bump!
Can somebody from developers have a look or at least point me in a right directions? It seems like MIMOLite and MIMO2+ are pretty popular devices.
I can provide more info if needed!
PS I know I can force interview to finish by just setting variables to true, not sure about consequences of that.
Thanks!
Please try in the latest release. We have fixed few things in it
kpanchen
Post by kpanchen »
Thanks Sergey, I've tried to update to 2.3.6 and however I see some differences and improvements interview is still failing:
For MIMO2+ it is still the same as I described, two CC's failed and forcing them seems like not doing anything.
I've tried to re-interview my Schlage BE469 lock and simple "Force Interview" button always stuck at 8% (which is one CC Security), if I force other CC's to re-interview they going through but two stuck completely: "Manufacture Specific" and "Version". Eventually "Manufacture Specific" went through, but "Version" not. From the log I see that lock is basically not responding to requests.
Thank you again!
lock.zip
Log for BE469
(1.63 KiB) Downloaded 702 times
The device is simply not answering. I believe it is because it ignores Version Get due to non-secure packet. And it is non-secure since Security failed during inclusion. So look here.
kpanchen
Post by kpanchen »
Interesting enough - I've re-included the lock and it did pass the interview without any problems from the first try. Still not sure what's up with MIMO2+.
Thanks!
