Hello all, and sorry for my english !
Configuration : Rasberry 2 with Domoticz, Z-Wave with UZB1 dongle
I have a mistake with my UZB 1 dongle after upgrade... and i can't do anythink now with the dongle...
To explain, i try to make a firmware update, after install the Z-Way server on a windows computer, and everythink i ok.
In expert UI i can see different firmware version and bootloader version.
In first, i do firmware update, comeback on expert UI and see a new firmware update with bootloader, i do fist bootloader, all OK
Back in Expert UI and a see new version, firmware 5.07 and bootloader (5.7 bootloader to 7278), and try the same order, bootloader... and a this moment, back to Expert UI, bootloader stay in the list... try again... stay in list...
Finaly, i try to instal the last firmware, and it's OK... but in expert UI the bootloader stay and impossible to install it now, always have ERROR in Expert UI...
It's impossible to restore any configuration on dongle, always in error, and only have access denied on z-way log...
finaly, i lost all device configuration, and it's now impossible to add anythink on rthe z-wave network !!!
What can i do with this dongle ?
What is this firmware 5.07 ? i only see some information for the 5.06 but nothink for 5.07 !
Is there any solution to back to a previous firmware and can try to retry for the last one ?
Thanks for your help
Gilles from Paris
UZB dongle Z-Wave error after upgrade !
Gilles.Gasman
Re: UZB dongle Z-Wave error after upgrade !
This is the Zway log when i try to restore configuration :
[2017-10-26 19:40:23.786] [core] --- ZWave.stop()
[2017-10-26 19:40:23.786] [core] --- Stopping module Z-Wave Network Access
[2017-10-26 19:40:23.836] [zway] Saving configuration data to config/zddx/e972e405-DevicesData.xml
[2017-10-26 19:40:23.862] [core] --- Starting module Z-Wave Network Access
[2017-10-26 19:40:23.925] [zway] Adding job: Get controller info and supported function classes
[2017-10-26 19:40:23.946] [zway] Adding job: Get or set Z-Wave.Me firmware capabilities
[2017-10-26 19:40:23.946] [zway] Adding job: Set Serial API timeouts
[2017-10-26 19:40:23.946] [zway] Adding job: Set RF power level
[2017-10-26 19:40:23.946] [zway] Adding job: WatchDog Start
[2017-10-26 19:40:23.946] [zway] Adding job: Change/Get Z-Wave.Me firmware frequency
[2017-10-26 19:40:23.946] [I] [zway] Adding job: Get home id and controller node id
[2017-10-26 19:40:23.946] [I] [zway] Removing job: Get controller info and supported function classes
[2017-10-26 19:40:23.956] [I] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): In progress
[2017-10-26 19:40:23.966] [I] [zway] Job 0xf5 (Get or set Z-Wave.Me firmware capabilities): Done
[2017-10-26 19:40:23.966] [I] [zway] Removing job: Get or set Z-Wave.Me firmware capabilities
[2017-10-26 19:40:23.977] [I] [zway] Job 0x06 (Set Serial API timeouts): Old timeouts are: ACK timeout 100 ms and Byte timeout 100 ms
[2017-10-26 19:40:23.977] [I] [zway] Removing job: Set Serial API timeouts
[2017-10-26 19:40:23.987] [I] [zway] Job 0x17 (Set RF power level): Done
[2017-10-26 19:40:23.987] [I] [zway] Removing job: Set RF power level
[2017-10-26 19:40:23.998] [I] [zway] Removing job: WatchDog Start
[2017-10-26 19:40:24.019] [I] [zway] Job 0xf2 (Change/Get Z-Wave.Me firmware frequency): Done
[2017-10-26 19:40:24.019] [I] [zway] Removing job: Change/Get Z-Wave.Me firmware frequency
[2017-10-26 19:40:24.030] [I] [zway] Job 0x20 (Get home id and controller node id): Home id: 0xe972e405, controller node id: 1
[2017-10-26 19:40:24.030] [I] [zway] Adding job: Get controller capabilities
[2017-10-26 19:40:24.030] [I] [zway] Adding job: Get controller version
[2017-10-26 19:40:24.030] [I] [zway] Adding job: Get SUC node id
[2017-10-26 19:40:24.030] [I] [zway] Adding job: Get initial data about network devices
[2017-10-26 19:40:24.030] [I] [zway] Adding job: Read bytes from extended EEPROM
[2017-10-26 19:40:24.030] [I] [zway] Removing job: Get home id and controller node id
[2017-10-26 19:40:24.042] [I] [zway] Removing job: Get controller capabilities
[2017-10-26 19:40:24.053] [I] [zway] Removing job: Get controller version
[2017-10-26 19:40:24.064] [I] [zway] Job 0x56 (Get SUC node id): SUC node is 1
[2017-10-26 19:40:24.064] [I] [zway] Removing job: Get SUC node id
[2017-10-26 19:40:24.167] [I] [zway] Adding job: Get node protocol information
[2017-10-26 19:40:24.167] [I] [zway] Adding job: Get routing table line
[2017-10-26 19:40:24.167] [I] [zway] Loading configuration data from config/zddx/e972e405-DevicesData.xml
[2017-10-26 19:40:24.176] [W] [zway] CC "MultiCmd" is not implemented
[2017-10-26 19:40:24.176] [W] [zway] CC "Security" is not implemented
[2017-10-26 19:40:24.176] [W] [zway] CC "CRC16" is not implemented
[2017-10-26 19:40:24.176] [I] [zway] Adding job: Set controller node information frame
[2017-10-26 19:40:24.176] [I] [zway] Loading Command Classes for device 1
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC Basic
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC ApplicationStatus
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC SwitchBinary
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC SwitchMultilevel
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC SceneActivation
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC ClimateControlSchedule
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC AssociationGroupInformation
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC DeviceResetLocally
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC CentralScene
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC ZWavePlusInfo
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC MultiChannel
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC ManufacturerSpecific
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC PowerLevel
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC NodeNaming
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC Clock
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC Version
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC Time
[2017-10-26 19:40:24.177] [I] [zway] Node 1:0 supports CC MultiChannelAssociation
[2017-10-26 19:40:24.177] [I] [zway] Node 1:1 supports CC Basic
[2017-10-26 19:40:24.177] [I] [zway] Node 1:2 supports CC Basic
[2017-10-26 19:40:24.177] [I] [zway] Node 1:3 supports CC Basic
[2017-10-26 19:40:24.177] [I] [zway] Node 1:4 supports CC Basic
[2017-10-26 19:40:24.177] [I] [zway] Node 1:5 supports CC Basic
[2017-10-26 19:40:24.177] [I] [zway] Node 1:6 supports CC Basic
[2017-10-26 19:40:24.178] [I] [zway] Node 1:7 supports CC Basic
[2017-10-26 19:40:24.178] [I] [zway] Node 1:8 supports CC Basic
[2017-10-26 19:40:24.178] [I] [zway] Node 1:9 supports CC Basic
[2017-10-26 19:40:24.178] [I] [zway] Node 1:10 supports CC Basic
[2017-10-26 19:40:24.178] [I] [zway] Node 1:11 supports CC Basic
[2017-10-26 19:40:24.178] [I] [zway] Node 1:12 supports CC Basic
[2017-10-26 19:40:24.178] [I] [zway] Node 1:13 supports CC Basic
[2017-10-26 19:40:24.178] [I] [zway] Node 1:14 supports CC Basic
[2017-10-26 19:40:24.178] [I] [zway] Node 1:15 supports CC Basic
[2017-10-26 19:40:24.178] [I] [zway] Node 1:16 supports CC Basic
[2017-10-26 19:40:24.178] [I] [zway] Node 1:1 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:2 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:3 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:4 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:5 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:6 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:7 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:8 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:9 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:10 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:11 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:12 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:13 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:14 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:15 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:16 supports CC SwitchBinary
[2017-10-26 19:40:24.178] [I] [zway] Node 1:1 supports CC SwitchMultilevel
[2017-10-26 19:40:24.178] [I] [zway] Node 1:2 supports CC SwitchMultilevel
[2017-10-26 19:40:24.178] [I] [zway] Node 1:3 supports CC SwitchMultilevel
[2017-10-26 19:40:24.178] [I] [zway] Node 1:4 supports CC SwitchMultilevel
[2017-10-26 19:40:24.178] [I] [zway] Node 1:5 supports CC SwitchMultilevel
[2017-10-26 19:40:24.178] [I] [zway] Node 1:6 supports CC SwitchMultilevel
[2017-10-26 19:40:24.178] [I] [zway] Node 1:7 supports CC SwitchMultilevel
[2017-10-26 19:40:24.178] [I] [zway] Node 1:8 supports CC SwitchMultilevel
[2017-10-26 19:40:24.178] [I] [zway] Node 1:9 supports CC SwitchMultilevel
[2017-10-26 19:40:24.178] [I] [zway] Node 1:10 supports CC SwitchMultilevel
[2017-10-26 19:40:24.178] [I] [zway] Node 1:11 supports CC SwitchMultilevel
[2017-10-26 19:40:24.178] [I] [zway] Node 1:12 supports CC SwitchMultilevel
[2017-10-26 19:40:24.178] [I] [zway] Node 1:13 supports CC SwitchMultilevel
[2017-10-26 19:40:24.178] [I] [zway] Node 1:14 supports CC SwitchMultilevel
[2017-10-26 19:40:24.179] [I] [zway] Node 1:15 supports CC SwitchMultilevel
[2017-10-26 19:40:24.179] [I] [zway] Node 1:16 supports CC SwitchMultilevel
[2017-10-26 19:40:24.179] [I] [zway] Node 1:1 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:2 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:3 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:4 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:5 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:6 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:7 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:8 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:9 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:10 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:11 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:12 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:13 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:14 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:15 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:16 supports CC SceneActivation
[2017-10-26 19:40:24.179] [I] [zway] Node 1:1 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:2 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:3 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:4 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:5 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:6 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:7 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:8 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:9 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:10 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:11 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:12 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:13 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:14 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:15 supports CC CentralScene
[2017-10-26 19:40:24.179] [I] [zway] Node 1:16 supports CC CentralScene
[2017-10-26 19:40:24.181] [I] [zway] Adding job: Get controller capabilities
[2017-10-26 19:40:24.181] [I] [zway] Removing job: Get initial data about network devices
[2017-10-26 19:40:24.192] [I] [zway] Removing job: Read bytes from extended EEPROM
[2017-10-26 19:40:24.203] [I] [zway] Removing job: Get node protocol information
[2017-10-26 19:40:24.214] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 1: [ ]
[2017-10-26 19:40:24.214] [I] [zway] Removing job: Get routing table line
[2017-10-26 19:40:24.225] [I] [zway] Removing job: Set controller node information frame
[2017-10-26 19:40:24.247] [I] [zway] Removing job: Get controller capabilities
[2017-10-26 19:40:39.145] [E] [zway] Failed to backup old configuration: Permission denied
Gilles.Gasman
This stay in firmware update windows...
Firmware Update
2017-05-12 5.7 Update bootloader to 7278
Firmware Update
Gilles.Gasman
No answer and i can see another guy with same problem....
Maybe a new firmware, or a fictive new ! can help us, and in this way maybe can apply bootloader and firmware 5.08 !
Is it possible to downgrade firmware ?
Where can we find the 5.06 binary file to try dowgrade ?
or change dongle if it's not possible... but still stay with a shit dongle at the moment...
Thanks for help
Thanks for help
Update the Dongle to 5.27 and you can downgrade to 5.06.
Regards
Regards
Gilles.Gasman
How to downgrade ????
- Z-Wave Support
with Z-Way you can upgrade you UZB to Version 5.27.
With Version 5.27 you can downgrade the UZB-Dongle to 5.06
Best regards
Z-Wave Support
Best regards
Z-Wave Support
Gilles.Gasman
Witch way to upgrade to 5.27 ? this release is not in upgrade screen on ZWAY !!!
