Dear all,
I have a question about HTTP Devices.
I built with a ESP32 and DHT22 sensor a easy ans cheap humidity and temperature sensor.
It is also possible that ESP sent the data to IP address with GET / POST.
I also can see the data in the browser on the IP address. Here is my code for the ESP.
At the moment I have problems to configure the HTTP Device. I'm really not a expert in programming HTTP /Java script...
Hope you can help me...
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println();
client.println("<!DOCTYPE HTML><html><head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<meta http-equiv=\"refresh\" content=\"30\"></head>");
client.println("<body><div style=\"font-size: 3.5rem;\"><p>ESP32 - DHT</p><p>");
if(atoi(celsiusTemp)>=25){
client.println("<div style=\"color: #930000;\">");
else if(atoi(celsiusTemp)<25 && atoi(celsiusTemp)>=5){
client.println("<div style=\"color: #006601;\">");
else if(atoi(celsiusTemp)<5){
client.println("<div style=\"color: #009191;\">");
Br, Ruffy
ESP32 and DHT22 HTTP Device
Re: ESP32 and DHT22 HTTP Device
Hi Ruffy,
here is my approach. Not sure it is what you are actually looking for, but maybe it will help.
I am using ESP32 based boards from Adafruit and Sweetpeas and TMP 36GT9 temperature sensors. These are configured as HTTP devices in the SmartHome UI.
On the ESP32 side, I use the ESP8266WebServer library to create a simple web server:
// web server
ESP8266WebServer server(80);
server.on("/temperature", handleTemperature);
An HTTP request for the temperature looks like this:
http://192.168.1.230/temperature
And the ESP32 response is coded as follows:
webString=""+String(temperatureC);
server.send(200, "text/plain", webString);
In a browser, you will just see the temperature returned.
From the SmartHome UI I setup an HTTP device as follows:
From the SmartHome UI, this results in a device on the dashboard:
The data is updated every 10 minutes. The readings are a little high and I need to revisit the code but for an idea as to how the HTTP side works you can see my code here https://github.com/babsk/ZWay-HTTP-Devi ... thermo.ino. This code also includes control of RF transmitters which I use for sockets/lamps.
I am using these temp sensors, as well as ZWave temperature sensors as part of my central heating / lighting solution which I occasionally blog about here https://kershawkids.blogspot.co.uk/
// web server
