otz/hex firmware updates
jeey
Post by jeey »
Hi
I know z-way can flash bin packaged updates, but can it flash otz/hex files as well?
Re: otz/hex firmware updates
Yes
In older versions otz might not be accepted. Rename it to ota
jeey
Post by jeey »
PoltoS any suggestions on to debug why an firmware isn´t be updated?
Have a firmware update that home-seer users are able to flash, but it doesn´t start in Zway.
No intresting data in web debugger or the log files based on my eyes.
Please try to run the upgrade with the device in unsecure mode (exclude it and include with security turned off). Please show me the log of your upgrade process (should be about 20 lines only) and ip:8083/JS/Run/zway.devices[XXXX].FirmwareUpdate.data.fragmentSize.value
jeey
Post by jeey »
30 Jun 2018 02:20
Thanks, this worked.
This is fixed in the latest RC, so the workaround will not be needed with the next release
jeey
Post by jeey »
Just to take this one further step. Should you be able to update firmware with bootloader embedded ?
When trying this i get error out of memory.
OTA firmwares do never contain bootloaders as this is very dangerous. Cut it out and make your update.
