Can't update apps
rafale77
Can't update apps
Post by rafale77 »
I see this in the log when I try to update an app in the smart home UI
And I get an error that it cannot download the update. I can however delete apps. I was suspecting that I had some folder permission issues.
[2018-07-26 18:08:11.333] [core] Installing app MailNotifier ...
[2018-07-26 18:08:11.334] [E] [HTTP] Callback execution error: ReferenceError: installer is not defined
at AutomationController.installModule (automation/classes/AutomationController.js:652:3)
at ZAutomationAPIWebRequest._.extend.updateModule (automation/ZAutomationAPIProvider.js:929:29)
at ZAutomationAPIWebRequest.ZAutomationWebRequest.handleRequest (automation/WebserverRequestRouter.js:259:35)
rafale77
Re: Can't update apps
Post by rafale77 »
Actually I am seeing more errors in different areas and have tried on a brand new installation too. I am suspecting that my installation of ubuntu either has some missing folders don't have the right folder permission. Could anyone tell me what folders zway downloads to?
Looks you are using some of the beta v2.3.8. Please confirm
rafale77
Post by rafale77 »
I am using 3.0.0 RC15. I just installed and tested 2.3.6 release after moving my config files to it and have the same problem so I doubt it is a problem with the zway itself. It is more likely due to some settings with my ubuntu install. I did not have these errors when I was on 3.0.0 RC12.
It should be with libraries. Start the s/w in shell and look in the stderr
rafale77
Post by rafale77 »
28 Jul 2018 01:21
aha... found something:
Failed to load module modskininstaller.so: /usr/lib/x86_64-linux-gnu/libcurl.so.4: version `CURL_OPENSSL_3' not found (required by ./modules/modskininstaller.so)
Module modcrypto.so loaded
Module modenocean.so loaded
Module modzbw.so loaded
Failed to load module modnotification2ext.so: /usr/lib/x86_64-linux-gnu/libcurl.so.4: version `CURL_OPENSSL_3' not found (required by ./modules/modnotification2ext.so)
Module moddhs.so loaded
Module modws.so loaded
Failed to load module modiconinstaller.so: /usr/lib/x86_64-linux-gnu/libcurl.so.4: version `CURL_OPENSSL_3' not found (required by ./modules/modiconinstaller.so)
Module modhomekit.so loaded
Failed to load module modhttp.so: /usr/lib/x86_64-linux-gnu/libcurl.so.4: version `CURL_OPENSSL_3' not found (required by ./modules/modhttp.so)
Module modzwave.so loaded
Module modsockets.so loaded
Failed to load module modinstaller.so: /usr/lib/x86_64-linux-gnu/libcurl.so.4: version `CURL_OPENSSL_3' not found (required by ./modules/modinstaller.so)
I checked my libraries and I do have libcurl.so.4. It is because libcurl4 is now compiled with OPENSSL_4 which standard on Ubuntu 18.04 LTS. Can you please update the modules so they can accept both 3 and 4?
spotifywebplayer
Contact:
Post by spotifywebplayer »
I having same problem.
ronie
Post by ronie »
Hey guys,
if you not already stumbled over it here is a workaround taken from https://depts.washington.edu/bitblog/20 ... ntu-18-04/
which shows you how to use libcurl3 "parallel" to libcur4 on Ubuntu 18.04
following lines should do the trick:
# install libcurl3
# this will temporarely overwrite/remove libcurl4
apt-get -y install libcurl3
# Making a copy of libcurl.so.4.5.0 and rename it to libcurl3.so.4.5.0
cp /usr/lib/x86_64-linux-gnu/libcurl.so.4.5.0 /usr/lib/x86_64-linux-gnu/libcurl3.so.4.5.0
# reinstall libcurl4 - libcurl3 will be overwritten but copied file will be still there
apt-get -y install libcurl4 libcurl4-openssl-dev
after that adjust the z-way-server script to inject the following line before lib injection:
# stop z-way-server
$ sudo /etc/init.d/z-way-server stop
# open init script in editor
$ sudo nano /etc/init.d/z-way-server
# add this line after: "# adding z-way libs to library path"
$env LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libcurl3.4.5.0
# next line is: "export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/z-way-server/libs"
# close editor by pressing [Ctrl]+[X] > Y > [Enter]
# start z-way-server
$ sudo /etc/init.d/z-way-server start
This solves this problem for me :)
sender
Post by sender »
Hi, found via google. I have z-way installed on ubuntu. I can't install any app.
Welcome to Ubuntu 18.04.4 LTS (GNU/Linux 4.15.0-99-generic x86_64)
Tried to install mqtt app but get error.
I have tried to apply above code. but how to proceed?
