Slow inclusion on large networks
boggibill
Post by boggibill »
Hi.
I currently doing an inclusion with 33 zwave units.
The first units are really fast, like included in less then a minute. However the last ones takes about 2 minutes to include.
Here is the inclusion time:
First unit: 15 seconds
Unit number 30: 120 seconds
As you can see the inclusion time increases dramatically when more units are added.
PS: All units are the same.
Does anyone know why this is happening and if it possible to avoid it somehow?
enbemokel
Re: Slow inclusion on large networks
Post by enbemokel »
15 sec. is veryfast, did you check in expert menu and then "jobs" if the inclusion is completely done?
Normaly there is some more communication after inclusion.
tin921
Post by tin921 »
i have the same problem. i have close to 60 devices actually. last few devices, i had to try a few times before the inclusion can complete. looking at the Job Queue during the inclusion progress, it looks like zway does a get route on all existing devices. i have to believe it has a huge impact on the 10-20 commands interview/request to the new device.
A deviceuring inclusion have to test all other devices if they are in direct range or not. This takes time if most of themte not reachable directly. Usually this is 30-40 seconds and then some 20-40 for interview. But if the device is far and routing is used, interview can take much longer
