Opening Firmware update/ Open updater
ends with the following error:
Error: html template error!
May be html_tmpl_dir conf parameter point to a wrong directory?..
happend after running >
by putty
due to >
The spawned process "get_z-way_version.sh" has exited with code 1 and says: ...
any clues?
V3.0.0 Firmare update/ Open updater error
Re: V3.0.0 Firmare update/ Open updater error
and a sudo reboot via putty rendered the z-way server inaccessible
what is the command for start stop server?
sudo service z-way-server start/stop/restart
or
suso /etc/init.d/z-way-server start/stop
or
Failed to start z-way-server.service: Unit z-way-server.service not found.
reformat sd card, reinstall stretch and then z way again?
z-way-server: unrecognized service
yeah v3 completely failed for me
had to roll back to v2.3.8
but not everything worked properly
Rollback cmd:
Rollback cmd:
wget -q -O - razberry.z-wave.me/install/v2.3.8 | sudo bash
Exactly the same here. Update to 3.0.1 did not work completely.
After first try it looked ok, UI reported Version 3.0.0, when launching Updater it still showed 2.3.8 and 3.0.1 available.
Second try to start Update brought total fail - z-way Service no longer available.
Thanks to the Roll-Back Command, I'm now back at 2.3.8 with all Settings available!
Now waiting for some news about how to do successful update?!
All latest z-way here:
https://storage.z-wave.me/z-way-server/
Flash sd card with this image:
https://storage.z-wave.me/z-way-server/ ... ch.img.zip
Then update z-way to latest version:
topcatsss wrote: ↑12 Sep 2019 00:52yeah v3 completely failed for me
Rollback cmd:Code: Select all
