Restore problem
Arek
Restore problem
Post by Arek »
I had to reinstall Raspbian. I want to restore my backup file (ZAB). Before I've done it in UI expert there was my devices (without names and details but there was 20 devices). I didn't restore Z-Wave network -> there was no devices. Reboot didn't help. So I try with Z-Wave network -> even worst. Can I do something with it or not?
Arek
Re: Restore problem
Post by Arek »
before restore there was info about Version 3.0.1 now:
Biker
Re: Restore problem
Post by Biker »
I have the same problem: https://forum.z-wave.me/viewtopic.php?f=3420&t=32943
Unfortunately still without solution. All backups are making the Z-way UI go astray. After each try I have to reinstall Raspbian.
The hints in the UI about the possible causes unfortunately do not apply, the controller is connected and recognizes the devices before the restore.
Arek
Re: Restore problem
Post by Arek »
I've try to factory reset but...
so how can I uninstall z-way?
Re: Restore problem
You have to check the RaZberry port configuration. Is it /dev/ttyAMA0 ? Are you using RaZberry?
Biker
Re: Restore problem
Post by Biker »
Thanks PoltoS, I figured it out on my own yesterday and here is a more a more detailed description:
As so often it is trivial. The problem is the UI port of the controller. The serial port of the controller has to be adjusted under Applications/Active Apps. For the GPIO Z-Wave controller it is /dev/ttyAMA0. For the USB stick /dev//dev/ttyACM0
I found some hints here: https://forum.z-wave.me/viewtopic.php?t=24707
Dear friends of zwave.me: you should urgently work on the documentation and the support, so that Z-Wave finally gets out of the handicraft corner. I assume that the majority of users have already invested a lot of money in this solution and can therefore expect more professionalism.
Arek
Re: Restore problem
Post by Arek »
yes, I'm using RaZberry. I had it like it should be:
and still not working
Arek
Re: Restore problem
Post by Arek »
Any hints?
Re: Restore problem
Please provide logs. Are you sure BT was disabled by the install script. If it is a Pi4, the script might not be correct for some models. What is your Pi?
Arek
Re: Restore problem
Post by Arek »
I disable bluetooth using this steps:
1. Open /boot/config.txt file.
sudo nano /boot/config.txt
2. Add below, save and close the file.
# Disable Bluetooth
dtoverlay=pi3-disable-bt
3. Disable related services.
sudo systemctl disable hciuart.service
sudo systemctl disable bluealsa.service
sudo systemctl disable bluetooth.service
4. Reboot to apply the changes
sudo reboot
not working. Which log do I have to put it here? Where can I find them? I need to be a progammer to use Razberry?!
How I wrote before:
Before I've done it (restore) in UI expert there was my devices (without names and details but there was 20 devices)
and there was also all apps, after restore - nothing is working.
