arm64 arch support
tbenr
arm64 arch support
Post by tbenr »
Hi all,
any chance to have z-way compiled for arm64 architecture?
i'm running a nanopc-T4 and there is only one armhf distro based on lubuntu-desktop which is quite uncomfortable.
E
Re: arm64 arch support
It is a pain to support too many platforms. IF there will be many users, we will focus on it.
tbenr
Post by tbenr »
But please consider even raspberry if moving quickly to 64bit kernels
The kernel is, but all libs are not (as stated in this screenshot). We will once they release a fully 64bits OS.
tbenr
Post by tbenr »
PoltoS wrote:
25 Dec 2019 01:34
true, right
DaddyMacCadillac
Post by DaddyMacCadillac »
tbenr wrote:
26 Nov 2019 02:31
Hi all,
E
+1 to this request. I have an Odroid N2 running Android 9 (64 bit) and have enabled tx and rx on my board via dtb overlay. When I try to execute z-way-server it can't communicate with my serial port /dev/ttyS1. I have tested my serial port via a loopback program so I know it's working. Really bummed I can't get this to work :|
If Z-Way is starting on you OS, it should work. The port problem should reside somewhere else.
Check your port configuration, permissions, logs to see more details, ...
tbenr
Post by tbenr »
at the moment i'm running an armhf distribution (ubuntu xenial) with a 64bit kernel. It works a part of this (https://forum.z-wave.me/viewtopic.php?f=3419&t=33248).
But a true 64bit would be better!
DaddyMacCadillac wrote:
13 Jan 2020 09:52
tbenr wrote:
26 Nov 2019 02:31
Hi all,
E
As told by PoltoS, this is another issue.
try to run z-way-server directly from the commandline (not from systemctl) and have a look to the stdout\err
tbenr
Post by tbenr »
full 64bit raspberry pi os is arriving: https://www.raspberrypi.org/forums/view ... 7&t=275370
francesco.alagna
Post by francesco.alagna »
Hi all, sorry if I reopen this old discussion topic.
I have a RaspberryPi 4 with Ubuntu Mate 21.10. I bought a Razberry board, but there's no way of installing the Z-Way software, as there's no pre-compiled package available for the arm64 architecture. My questions are:
  • Is there any way of using the Razberry without the Z-Way software (any alternative?)
    Is there a chance to get a arm64 package for it?
If the answer is "no" to both questions, I am afraid I have to send the board back.
