Logical Rule
HeHa
Logical Rule
Post by HeHa »
when I activate a scene, then I want a rule to execute.
The rule works, but I can not make it trigger by activating the scene.
As soon as I add the scene under "trigger the rule check on activation of the following scenes" the rule does not execute.
This is my setup. What is wrong?
2020-02-18 23_51_46-Window.png (31.36 KiB) Viewed 18399 times
2020-02-18 23_55_15-Window.png (31.95 KiB) Viewed 18399 times
I can see from notofication sent that the scene activates.
I do not get any notifications from the rule when "trigger the rule check on activation of the following scenes" is activated.
Thank you.
/HeHa
raZberry with firmware version: v3.0.4-33-gfb22f31
