Hi, I´ve upgraded the firmware on my RazBerry to the latest available version 3.0.5.
Now the homekit App doesn´t work anymore. deinstallation of the app work, but re-install doesn´t work.
please see attached video.
br. llcoolk
https://www.dropbox.com/s/b3j100ahcu9f3 ... t.mp4?dl=0
Problem with Homekit App after update 3.0.5
Re: Problem with Homekit App after update 3.0.5
Can you show the log? What is the error?
- Bildschirmfoto 2020-04-13 um 09.00.43.jpg (77.95 KiB) Viewed 10592 times
Try with another name, RaZberry1
Done that, same result!
- Bildschirmfoto 2020-04-13 um 13.15.14.jpg (23.37 KiB) Viewed 10566 times
Can you open the log and show the output when the app is launched (with a new name - it woks only first time after rename).
To do it connect to the Pi via SSH and do:
tail -f /var/log/z-way-server.log
We only need the log around that error
ok,
[2020-04-14 08:30:00.882] [D] [zway] Job 0x13 (SensorBinary Get v2): removing duplicate
[2020-04-14 08:30:00.882] [core] --- ZWayVDev_zway_16-0-113-7-8-A performCommand processing: {"0":"update"}
[2020-04-14 08:30:00.883] [zway] Using security scheme S0
[2020-04-14 08:30:00.883] [D] [zway] Job 0x13 (Alarm Get (v3)): removing duplicate
[2020-04-14 08:30:00.883] [core] --- ZWayVDev_zway_16-1-48-12 performCommand processing: {"0":"update"}
[2020-04-14 08:30:00.883] [D] [zway] Job 0x13 (SensorBinary Get v2): removing duplicate
[2020-04-14 08:30:00.883] [core] --- ZWayVDev_zway_16-1-113-7-8-A performCommand processing: {"0":"update"}
[2020-04-14 08:30:00.884] [zway] Using security scheme S0
[2020-04-14 08:30:00.884] [D] [zway] Job 0x13 (Alarm Get (v3)): removing duplicate
[2020-04-14 08:32:22.669] [core] Instantiating module 7 from class HomeKitGate
[2020-04-14 08:32:22.682] [core] --- Starting module Apple HomeKit Gateway
[2020-04-14 08:32:23.249] [core] Notification: error (core): Das Modul kann nicht instanziiert werden: HomeKitGate: TypeError: Cannot read property 'data' of undefined
[2020-04-14 08:32:23.262] [core] TypeError: Cannot read property 'data' of undefined
at onDeviceAddedCore (automation/userModules/HomeKitGate/index.js:291:75)
at Function._.each._.forEach (automation/lib/underscore.js:153:9)
at _.extend.each (automation/classes/DevicesCollection.js:181:12)
at HomeKitGate.init (automation/userModules/HomeKitGate/index.js:587:26)
at AutomationController.instantiateModule (automation/classes/AutomationController.js:498:13)
at AutomationController.createInstance (automation/classes/AutomationController.js:938:17)
at ZAutomationAPIWebRequest._.extend.createInstance (automation/ZAutomationAPIProvider.js
31)
at ZAutomationAPIWebRequest.ZAutomationWebRequest.handleRequest (automation/WebserverRequestRouter.js:263:35)
at WebServer.document_root (automation/Webserver.js:36:11)
[2020-04-14 08:32:28.531] [I] [core] Instantiating module 7 from class HomeKitGate
[2020-04-14 08:32:28.532] [I] [core] --- Starting module Apple HomeKit Gateway
[2020-04-14 08:32:28.561] [I] [core] Notification: error (core): Das Modul kann nicht instanziiert werden: HomeKitGate: Error: HomeKit instance Zwave HomeKit is already in use
[2020-04-14 08:32:28.570] [I] [core] Error: HomeKit instance Zwave HomeKit is already in use
at Error (native)
at HomeKitGate.init (automation/userModules/HomeKitGate/index.js:37:12)
31)
[2020-04-14 08:32:42.485] [D] [zway] RECEIVED: ( 01 09 00 04 00 0A 03 80 03 3C 44 )
[2020-04-14 08:32:42.485] [D] [zway] SENT ACK
[2020-04-14 08:32:42.485] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2020-04-14 08:32:42.485] [D] [zway] SETDATA devices.10.instances.0.commandClasses.128.data.history.60 = 1586845962 (0x5e95590a)
[2020-04-14 08:32:42.485] [D] [zway] SETDATA devices.10.instances.0.commandClasses.128.data.last = 60 (0x0000003c)
[2020-04-14 08:32:42.496] [D] [zway] RECEIVED: ( 01 0C 00 04 00 0A 06 43 03 01 42 08 34 C4 )
[2020-04-14 08:32:42.496] [D] [zway] SENT ACK
[2020-04-14 08:32:42.496] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2020-04-14 08:32:42.497] [D] [zway] SETDATA devices.10.instances.0.commandClasses.67.data.1.size = **********
[2020-04-14 08:32:42.497] [D] [zway] SETDATA devices.10.instances.0.commandClasses.67.data.1.precision = **********
[2020-04-14 08:32:42.497] [D] [zway] SETDATA devices.10.instances.0.commandClasses.67.data.1.deviceScale = 0 (0x00000000)
[2020-04-14 08:32:42.497] [D] [zway] SETDATA devices.10.instances.0.commandClasses.67.data.1.deviceScaleString = "°C"
[2020-04-14 08:32:42.497] [D] [zway] SETDATA devices.10.instances.0.commandClasses.67.data.1.val = 21.000000
[2020-04-14 08:32:42.497] [D] [zway] SETDATA devices.10.instances.0.commandClasses.67.data.1.setVal = 21.000000
[2020-04-14 08:32:42.497] [D] [zway] SETDATA devices.10.instances.0.commandClasses.67.data.1 = Empty
[2020-04-14 08:32:42.515] [D] [zway] RECEIVED: ( 01 0A 00 04 00 0A 04 46 08 00 7F CE )
[2020-04-14 08:32:42.522] [D] [zway] SENT ACK
[2020-04-14 08:32:42.522] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2020-04-14 08:32:42.535] [D] [zway] RECEIVED: ( 01 08 00 04 00 0A 02 84 07 78 )
[2020-04-14 08:32:42.535] [D] [zway] SENT ACK
[2020-04-14 08:32:42.535] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2020-04-14 08:32:42.535] [I] [zway] Node 10:0 CC Wakeup: Wakeup notification
[2020-04-14 08:32:42.535] [D] [zway] SETDATA devices.10.instances.0.commandClasses.132.data.lastWakeup = 1586845962 (0x5e95590a)
[2020-04-14 08:32:42.536] [D] [zway] SETDATA devices.10.data.isAwake = True
[2020-04-14 08:32:42.536] [D] [zway] SETDATA devices.10.data.lastSendInternal = **********
[2020-04-14 08:32:42.536] [D] [zway] SETDATA devices.10.data.lastNonceGet = 20463585 (0x01383fe1)
[2020-04-14 08:32:42.536] [D] [zway] Running wakeup handler for node 10
[2020-04-14 08:32:42.536] [D] [zway] SETDATA devices.10.instances.0.commandClasses.132.data.lastSleep = 1586845962 (0x5e95590a)
[2020-04-14 08:32:42.536] [I] [zway] Node 10:0 CC Wakeup: Send node to sleep
[2020-04-14 08:32:42.536] [I] [zway] Adding job: Wakeup Sleep
[2020-04-14 08:32:42.537] [D] [zway] SENDING (cb 0xae): ( 01 09 00 13 0A 02 84 08 05 AE CA )
[2020-04-14 08:32:42.545] [D] [zway] RECEIVED ACK
[2020-04-14 08:32:42.545] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-04-14 08:32:42.545] [D] [zway] SENT ACK
[2020-04-14 08:32:42.545] [D] [zway] Delivered to Z-Wave stack
[2020-04-14 08:32:42.566] [D] [zway] RECEIVED: ( 01 07 00 13 AE 00 00 01 44 )
[2020-04-14 08:32:42.566] [D] [zway] SENT ACK
[2020-04-14 08:32:42.566] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2020-04-14 08:32:42.567] [D] [zway] SendData Response with callback 0xae received: received by recipient
[2020-04-14 08:32:42.567] [D] [zway] SETDATA devices.10.data.lastSendInternal = **********
[2020-04-14 08:32:42.567] [D] [zway] SETDATA devices.10.data.lastSend = 20464588 (0x013843cc)
[2020-04-14 08:32:42.567] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2020-04-14 08:32:42.567] [D] [zway] SETDATA devices.10.data.isAwake = False
[2020-04-14 08:32:42.567] [D] [zway] Sending the queue for node 10 into sleep
[2020-04-14 08:32:42.567] [I] [zway] Removing job: Wakeup Sleep
at Error (native)
hi, any info on that so far?
Press Save button in HomeKit Gate and show JS error in browser console.
