UZB Update problem - UZB Controller blinking without pause
Clubber2000
Post by Clubber2000 »
After listening today to the very interresting webinar I rocognized that my UZB firmware was quit old.
After several firmware and Bootloader updates of my UZB I am now on:
Firmware
SDK Version: 6.81.01
Serial API Version: 05.34
Why does the updater there not offers the 05.36 Version to me? Only a downgrade would be possible like you can see on the picture:
The second problem is: from the moment of ending the update process of the UZB firmware, the controller build in LED is blinking all the time without any pause? Is this normal? I dont think so. Everything seems to work normal in my system like before.
What could be the reason for such a great data traffic over the UZB controller. The controller queue shows this:
Re: UZB Update problem - UZB Controller blinking without pause
If you look here (https://service.z-wave.me/expertui/uzb- ... ith_hidden) you will see that for somewhat reason 5.34 have no switch to 5.36, but you can go back to 5.33->5.27->5.36
Blinking is okey - this will be fixed in next release.
The queue is okey, this was discussed during the webinar, W flag is normal especially after Z-Way restart.
Clubber2000
Thanks PoltoS. Update worked. The update grafik is really crazy. :)
So I just have to wait for the update which stops disco style UZB stick in my living room.
Clubber2000
Today I was lucky to see that a new UZB firmware version is out:
How can I switch to this version from 5.36? The only offered version in the expert menu is a downgrade to 5.27. I tried the downgrade in the hope to upgrade from 5.27 to 5.37. But only again upgrade to 5.36 as the newest version.
PoltoS could you please advice how to update to the firmware with the solution to the always blinking led?
Clubber2000
My UZB ist still blinking. Is there no way to upgrade the Firmware via the Expert UI?
anom3
Post by anom3 »
A) 5.37 is out but not really out... According to https://service.z-wave.me/expertui/uzb- ... graph.html its not even in the list of options... Plotous should chime in here...
B) The blinking appears to be a bug... Do a start inclusion / stop inclusion. I have the same behavior on 2 of my uzb sticks. Looks like it starts up in inclusion mode.
Clubber2000
Thanks anom3 for your helpful response.
Doing a start / stop inclusion stops the blinking. Perfekt. I hope it lasts for a longer period.
Soni1c
Post by Soni1c »
Simply plug the cable into a USB port on your console and connect the other end to your controller Sonic Breakfast Hours
