Philips Hue app?
Minux
Re: Philips Hue app?
Post by Minux »
can you grep "hue" in ./var/log/z-way-server.log ?
maob79
Post by maob79 »
I have a similar issue. After a reboot all my hue devices disappear. All the other z-wave devices are still there and working fine.
Once I opened the settings of the hue app and click on save without changing anything, the devices are back.
But that's quite annoying to do that after every reboot. What am I doing wrong? Is there a way to "automate" that?
Looks like some race condition an start. Worth to look with tcpdump and compare
maob79
Post by maob79 »
I looked into the z-way-server-log and found the following entries after a reboot (blanked out the end of the API-key):
[2020-03-21 08:34:39.290] [core] Loading module Hue from userModules/Hue
[2020-03-21 08:34:39.299] [core] Executing script: /** Hue Z-Way HA module ******************************************* ...
[2020-03-21 08:34:39.311] [core] Instantiating module 16 from class Hue
[2020-03-21 08:34:39.312] [core] Hue Init Devices
[2020-03-21 08:34:39.312] [core] --- Starting module Philips Hue
[2020-03-21 08:34:39.335] [core] Hue Authenticate Devices
[2020-03-21 08:34:45.903] [core] Hue Erreur Connection Authenticate: http://192.168.1.121/api/7JgVNcAiKog0LB ... 5ciXXXXXXX
[2020-03-21 08:34:45.904] [core] Hue Finished Auth: http://192.168.1.121/api/7JgVNcAiKog0LB ... cicpfXXXXX
Don't know what exactly that means.
If I then go in the app and click on "safe" without changing anything, the authentication works just fine:
[2020-03-21 10:12:29.093] [core] Hue Connection Authenticate OK -> {"status":200,"statusText":"OK","url":"http://192.168.1.121/api/7JgVNcAiKog0LB ... ccess-Cont
If you could help us to remotely debug it, we can fix it
maob79
Post by maob79 »
Sure. What do you need to remotely debug it?
Christian12
Post by Christian12 »
maob79 wrote:
20 Feb 2020 14:46
Same issue Here, is there a workaround To fix? That Problem is in the 0.98 Version in the App Store, also in the 1.1 Version from Timauton at GitHub.
Eagle
Post by Eagle »
Does anybody have a working Hue app since upgrading to 3.1 or 3.1.1?
Only my first 3 hue lamps are getting recognized in zway, while my other 20+ lamps are not selectable.
insiorc
Post by insiorc »
Eagle wrote:
02 Nov 2020 10:39
Yes I'm on 3.1.1 and my Hue app is working fine. Only issue is if I reboot the Raspberry Pi I need to remember to go into the app and save or it doesn't work.
Rpi4 2Gb, Z-Way 3.2.2, UZB 5.39
Eagle
Post by Eagle »
Which version of the hue app are you using? v1.1 from github or v0.98 from the store?
Thanks for the reply, now i know, that there is a problem with my system
