Heating Control - does not work
JoLu
Post by JoLu »
a created some schedules in the heating control application for my thermostats in the rooms but all of them have no effect means no action to the deviec are triggered although the active swith is set (see screenshot).
Can you give me some advice what may be wrong in general.
(if I use schedules instead of the heating control they a working but they a not so well-arranged of course)
POPP
Firmware version v3.2.0
UI version v1.13.2
Built date 24-08-2021 23:55:22
Re: Heating Control - does not work
Sure you have thermostats in that room?
JoLu
Post by JoLu »
Sure there is a thermostat named "Badezimmer" in that room. Also for all other room with thermostats I have the same issue. For none of the the "Heating control" works. So possible I made a general mistake or don't understand the functionality.
Thermostat Badezimmer.JPG (69.19 KiB) Viewed 11137 times
J.nissen
Post by J.nissen »
i have the same efekt ( Problem )
Greetings from germany
Jörg
Could you please provide access (admin login with temp password), so we can check it
J.nissen
Post by J.nissen »
Heizung 2.png (125.73 KiB) Viewed 10223 times
No Event are Triggered
Thanks for your Help
Jörg
