Route Map has no Data
J.nissen
Post by J.nissen »
I use Razberry gen. 7 +
I had no Rout Map .
An Errormessage Occur
Too few nodes to make statistics
Your UZB/RaZberry/Hub do not have advanced network statistics. Upgrade the firmware
Can not set route from battery device to a battery device
Can not set route with battery repeaters
The current firmware version is: 7.11 [Bootloader: 1766938484]
Greetings from germany
Jörg
Re: Route Map has no Data
Looks like a UI error. What do you see in the browser log?
J.nissen
Post by J.nissen »
Hello PoltoS,
I have test it with
- Firefox
- chrom
- Edge
which Logfile do you mean ?
Jörg
you can check the browser log in Chrome to see for errors. Or provide us access to check it.
J.nissen
Post by J.nissen »
Hello Poltos,
you can access over the Credentials that I have send to you in Past....
Please sea in your Private Messages ( Subject : Heating Control ... ).
[15408:7172:0119/120244.919:INFO:CONSOLE(1332)] "Adding actual route 76 -> 33 to official neighbour list", source: http://192.168.102.153:8083/expert/app/js/build.js (1332)
[15408:7172:0119/120244.919:INFO:CONSOLE(1332)] "Adding actual route 78 -> 1 to official neighbour list", source: http://192.168.102.153:8083/expert/app/js/build.js (1332)
[15408:7172:0119/120244.919:INFO:CONSOLE(1332)] "Adding actual route 78 -> 26 to official neighbour list", source: http://192.168.102.153:8083/expert/app/js/build.js (1332)
[15408:7172:0119/120244.919:INFO:CONSOLE(1332)] "Adding actual route 78 -> 29 to official neighbour list", source: http://192.168.102.153:8083/expert/app/js/build.js (1332)
[15408:7172:0119/120244.922:INFO:CONSOLE(1452)] "Error: missing: 9
at vu (http://192.168.102.153:8083/expert/app/ ... 1317:19149)
at r (http://192.168.102.153:8083/expert/app/ ... 1321:11592)
at Function.Gg.e.initialize (http://192.168.102.153:8083/expert/app/ ... 1321:12054)
at i (http://192.168.102.153:8083/expert/app/ ... 1321:12941)
at Object.force (http://192.168.102.153:8083/expert/app/ ... 1321:13590)
at f.initNodes (http://192.168.102.153:8083/expert/app/ ... s:1356:370)
at new f (http://192.168.102.153:8083/expert/app/ ... s:1343:111)
at http://192.168.102.153:8083/expert/app/ ... s:19815:27
at C (http://192.168.102.153:8083/expert/app/ ... s:1460:187)
at http://192.168.102.153:8083/expert/app/ ... s:1461:350", source: http://192.168.102.153:8083/expert/app/js/build.js (1452)
[23200:27212:0119/120244.923:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: https://safebrowsing.googleapis.com/v4/ ... 1OpBXqWBgw
[23200:27212:0119/120244.924:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZAutomation ... ect892.png
[23200:27212:0119/120245.648:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120246.648:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120247.648:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[15408:13264:0119/120248.523:VERBOSE1:cast_socket.cc(294)] [192.168.102.147:8009, auth=SSL_VERIFIED] Timeout while establishing a connection.
[15408:13264:0119/120248.523:VERBOSE1:cast_socket.cc(652)] [192.168.102.147:8009, auth=SSL_VERIFIED] SetErrorState ChannelError::CONNECT_TIMEOUT
[15408:13264:0119/120248.523:VERBOSE1:cast_socket.cc(574)] DoConnectCallback (error_state = ChannelError::CONNECT_TIMEOUT)
[15408:13264:0119/120248.523:VERBOSE1:cast_socket.cc(614)] [192.168.102.147:8009, auth=SSL_VERIFIED] Close ReadyState = ReadyState::CONNECTING
[23200:27212:0119/120248.648:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120249.649:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120250.649:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120251.655:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120252.652:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120253.648:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120254.655:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120255.962:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120256.966:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[15408:13264:0119/120257.360:VERBOSE1:cast_socket.cc(219)] [192.168.102.147:8009, auth=SSL_VERIFIED] Connect readyState = ReadyState::NONE
[15408:13264:0119/120257.360:VERBOSE1:cast_socket.cc(378)] [192.168.102.147:8009, auth=SSL_VERIFIED] DoTcpConnect
[15408:13264:0119/120257.360:VERBOSE1:cast_socket.cc(392)] [192.168.102.147:8009, auth=SSL_VERIFIED] DoTcpConnectComplete: 0
[15408:13264:0119/120257.360:VERBOSE1:cast_socket.cc(409)] [192.168.102.147:8009, auth=SSL_VERIFIED] DoSslConnect
[23200:27212:0119/120257.973:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120258.965:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120259.964:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120300.969:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120301.965:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120302.970:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120303.655:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120304.650:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120305.654:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120306.659:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[15408:13264:0119/120307.364:VERBOSE1:cast_socket.cc(294)] [192.168.102.147:8009, auth=SSL_VERIFIED] Timeout while establishing a connection.
[15408:13264:0119/120307.364:VERBOSE1:cast_socket.cc(652)] [192.168.102.147:8009, auth=SSL_VERIFIED] SetErrorState ChannelError::CONNECT_TIMEOUT
[15408:13264:0119/120307.364:VERBOSE1:cast_socket.cc(574)] DoConnectCallback (error_state = ChannelError::CONNECT_TIMEOUT)
[15408:13264:0119/120307.364:VERBOSE1:cast_socket.cc(614)] [192.168.102.147:8009, auth=SSL_VERIFIED] Close ReadyState = ReadyState::CONNECTING
[23200:27212:0119/120307.658:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120308.655:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120309.974:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120310.976:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120311.972:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120312.975:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120313.967:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120314.976:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120315.653:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120316.659:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120317.651:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120318.658:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[15408:13264:0119/120319.485:VERBOSE1:cast_socket.cc(219)] [192.168.102.147:8009, auth=SSL_VERIFIED] Connect readyState = ReadyState::NONE
[15408:13264:0119/120319.485:VERBOSE1:cast_socket.cc(378)] [192.168.102.147:8009, auth=SSL_VERIFIED] DoTcpConnect
[15408:13264:0119/120319.565:VERBOSE1:cast_socket.cc(392)] [192.168.102.147:8009, auth=SSL_VERIFIED] DoTcpConnectComplete: 0
[15408:13264:0119/120319.565:VERBOSE1:cast_socket.cc(409)] [192.168.102.147:8009, auth=SSL_VERIFIED] DoSslConnect
[23200:27212:0119/120319.666:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120320.666:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
[23200:27212:0119/120321.649:VERBOSE1:network_delegate.cc(34)] NetworkDelegate::NotifyBeforeURLRequest: http://192.168.102.153:8083/ZWave.zway/InspectQueue
Jörg
Thanks, we have fixed it for the next release. This was because of a strange issue that your node #9 is marked as Portable controller rather than a Slave device. Very strange. You should fix it by assigning zway.devices[9].data.basicType = 4
J.nissen
Post by J.nissen »
thanks for your help.
Where can I Change the settings ?
Jörg
micky1500
Post by micky1500 »
This might do it !
Login as normal to the dashboard. Using Chrome
192.168.102.153:8083/smarthome/#/dashboard
Log in and Leave that page open, Then open a new tab Cntl-T
Paste this command into the Address bar, then press enter.
192.168.102.153:8083/JS/Run/zway.devices[9].data.basicType=4
you should get a response of "4"
J.nissen
Post by J.nissen »
Hallo,
Great routemap works
Jörg
