Z-way-server occasionally goes down
GokMasE
Re: Z-way-server occasionally goes down
Post by GokMasE »
This is in every possible way extremely exciting news for me!
When trying to diagnose the nature of the crash, I was experimenting with adding a buffering scheme in HTTPGet and quickly discovered that buffering requests (and setting a limit on how often they are allowed to be sent) clearly helped reduce the risc of crashes. It was however when I modified the HTTPGet even further to make it use syncronized http requests (rather than the default async), that I noticed that this seemed to completely prevent the server from crashing. So the final clue was that something was disturbing the server between the http request being sent and the resulting (asyncronous) reply.
I now have the new development build (z-way-4.0.2-4-ge4433cb0-lws16_armhf.deb) installed and running the usual stress testing environment and must say that the results so far is very encouraging - it has been running smoothly for >27 hours by now! (I have of course reverted to the original HTTPGet module, and with the stressful test case I am running this would typically lead to a SIGSEGV crash within 2-6 hours)
I do want to keep the test running for a while before I dare stating the problem is 100% cured, but this is looking very promising indeed.
Huge thanks to PoltoS for always listening to feedback and never giving up! :)
JohannesF
Post by JohannesF »
Same here.
My system is running for nearly 40 hours.
I have increased the pressure by adding another 7 HTTP devices to now have a total of 27.
I hope it will keep going.
harveybabes
Post by harveybabes »
Hi, I have had similar problems over time and I assumed it was the constant writing to the SD card. I always keep an img file of my latest setup but was sick of buying new cards.
Although it may not be ideal for everybody, I have seemed to have stopped the crashing by creating a CRON job for removing the log, tmp and message files form /var/log and then a clean reboot every few hours (when I know I may be asleep etc).
@harveybabes the problem you describe does not look to be related to this bug. Or it was just a coincidence that lead you to link it to clearing logs.
If you had a lot of async HTTP requests, it was certainly this bug.
JohannesF
Post by JohannesF »
@harveybabes: If you don't work a lot with the log file it may make sense to reduce the amount and depth of information captured in the log file.
This is defined in the file /opt/z-way-server/config.xml
There should be a line
<log-level>2</log-level>
The numeric value determines the amount of information. 0= log all, 9 = log almost nothing.
As much as I recall, 0 is the default.
You may want to reduce the log level as needed. 2 has been a good compromise for me.
On a Raspi you can edit the file with
sudo nano /opt/z-way-server/config.xml
And install logrotate (should be installed by default and from v4.0.2 it is installed via dependency). It will remove older logs and keep your folder reasonable
piet66
Post by piet66 »
I have implemented another idea: Put the whole z-way-server folder and the log onto an additional USB drive.
I think a good USB drive will last longer than a SD card. And if it fails, it can be exchanged much easier.
harveybabes
@JohannesF : thanks
GokMasE
Post by GokMasE »
I had a power outage this morning, so my test session was unfortunately abruptly terminated after ~40 hours of uptime :roll:
Until that happened, I have not been able to detect any stability issues. I will restart things tonight and carry on testing.
lanbrown
Post by lanbrown »
GokMasE wrote:
16 Jan 2023 13:58
That's why I'm moving my systems to CM4 modules on a carrier board that supports PoE and has a UPS functionality built-in to the carrier board.
https://www.waveshare.com/wiki/CM4-POE-UPS-BASE
