Qubino meter Firmware update
AlesKO
Post by AlesKO »
Today I received .otz firmware upgrade file for 3 Phase SmartMeter from Qubino.
Opened Device > Firmweare update in Expert mode, selected otz file... and nothing.
Just for short time 0% on red background appears, then nothing happens.
Any suggestions?
AlesKO
Re: Qubino meter Firmware update
Post by AlesKO »
Solved my problem. Firmware is finally updated. It is really pitty that z-way does not report reason for FW update failure.
Now after upgrade, meter values are not displayed as before 2.3 kW but as 4.26e+3 W
Is there a way to change it or it is defined by device ?
A.
micky1500
Post by micky1500 »
It's new Firmware, Therefore a new device.
Re-Interview might pick up the changes.
if that doesn't work.. Try remove and re-install.
I'd Guess 'Select Device Description' might be too old and outdated, but worth a try.
Where do you see 4.26e+3 ? we should never show such values in the UI...
AlesKO
Post by AlesKO »
Attached screenshot...
AlesKO
Post by AlesKO »
Checked with our R&D. The scientific format is used for only super small numbers and by error is applied to negative numbers too.
This is fixed and will be part of the next release: https://github.com/Z-Wave-Me/zwave-smar ... 6ac3bbe916
