Downgrade Firmware Razzberry 7
J.nissen
Post by J.nissen »
how can I Downgrad den Razzberry 7 Firmware ?
The current firmware version is: 7.38 [Bootloader: 1766938484], I want to install an previous Version.
Since I have installed 7.38 the System Hangs up daily
Greetings from germany
Jörg
J.nissen
Re: Downgrade Firmware Razzberry 7
Post by J.nissen »
is there rellay no way back ?
Jörg
harre
Post by harre »
I have almost given up on my razzberry. My smart home is really stupid and I have posted some threads for a while with various issues and given logs and still no response from any developer.
seattleneil
Post by seattleneil »
As best as I can tell from looking at other Z-Wave controller software (see: https://github.com/zwave-js/node-zwave-js/issues/6341) and SIlicon Labs release notes (see: https://www.silabs.com/documents/public ... .3.1.0.pdf), there's at least 1 known memory leak and stability issues with 700 series modules.
The zwave-js developers suggest a workaround for 700-series stability issues by periodically doing a soft reset. Since this is non-destructive and only interrupts Z-Wave communication for a couple of seconds, You may want to try setting up a daily cron job to issue a Z-Way API command to perform a soft reset and see if that helps. Something like the following:
curl -u admin:[PASSWORD] --globoff 'http://127.0.0.1:8083/ZWave.zway/Run/SerialAPISoftReset()'
harre
Post by harre »
seattleneil wrote: ↑
05 Oct 2023 07:51
OMG!
This fixed my issues that have plagued me for last six months. Why can't they have posted here in the forums about it and also made the deb-package install a Cron as a workaround for affected devices.
J.nissen
Post by J.nissen »
since I have installed Workarround i have never had Errors again. All Sheduled job´s startet. Many thanks to @seattleneil
Jörg
amatilda
Post by amatilda »
Hello.
J.nissen wrote: ↑
14 Sep 2023 10:01
And in what form does this manifest itself?
