Z-Station Firmware Updates and Zwave JS Settings
JasonJoel
Post by JasonJoel »
Which firmware should be used for updating the Z-Wave firmware on the Z-Station? I see no references to Z-Station at all in the firmware areas of the site.
Also, is there any guidance on configuring Z-Station with Zwave JS? Before someone asks - I use Zwave JS instead of Z-Way as I have a lot of issues with Zwave LR devices not completing interviews, etc, on Z-Way while they work fine on Zwave JS.
For instance, what values should be used for these settings:
"Normal Power Level"
"Measured output power at 0 dBm"
Thank you,
Jason
Re: Z-Station Firmware Updates and Zwave JS Settings
Sorry, I don't understand your question. Please provide more info about Z-Way issues: logs.
JasonJoel
Post by JasonJoel »
1. Any comment on which z-wave firmware to use for the Z-Station?
2. Any comment on the power settings on Zwave JS?
3. As far as the Z-Wave LR issues on z-way:
As starting points:
https://forum.z-wave.me/viewtopic.php?f=3419&t=35945
https://forum.z-wave.me/viewtopic.php?f=3419&t=35944
Thanks,
Jason
EDIT:
Screenshot of the Zwave JS settings in question is attached.
Screenshot 2024-04-23 183312.png (91.45 KiB) Viewed 19654 times
Those two TX controls will not work on Z-Station - it uses another mechanism available in Z-Way via
http://localhost:8083/JS/Run/zway.SerialAPISetupSetTxPower(50)
. But the default power should be more than enough!
The frequency should also be changed via Z-Way or using the command described here: https://z-wave.me/support/serial-api-commands/
JasonJoel
Post by JasonJoel »
Thank you. As I mentioned I do not use Z-Way since it will not complete interviews on so many of my Z-Wave LR devices.
As the Z-Station is working OK on zwave js ui with the default settings, include Z-Wave LR, I will just leave everything at the default.
Jason
Could you please help us understand what is wrong wit h your LR devices? Z-Way is perfectly working for hundreds of different devices including dozens of LR devices. I'm curious to see the inclusion log.
And yes, Z-Station's antenna is so good that it should work as is.
jens_s
Post by jens_s »
When I try to find out the firmware by
./zme_zigbee info -d /dev/ttyUSB1
i get an error Message
-bash: ./zme_zigbee: Permission denied
JasonJoel
Post by JasonJoel »
PoltoS wrote:
12 May 2024 03:27
jens_s wrote:
12 May 2024 13:10
You might need to do
chmod +x zme_zigbee
first.
jens_s
Post by jens_s »
thank you, that works.
