Updating to Z-Way v4.1.4 fails
GokMasE
Post by GokMasE »
I noticed there is a new version of Z-Way available and tried to update to v4.1.4 via smarthome UI ( /settings/firmware update/Open updater) but only to see this message:
Err(1.18.3): main.c: 501: The spawned process 'shell:/bin/systemctl stop netif.$IFACE' has exited with code 5 and says:
I am currently running Z-Way v.4.1.3 on a Raspberry 3 using Buster.
Is this some kind of known issue that is likely to be fixed or should I try to force an update via PuTTY?
Regards,
/Joakim
otverber
Re: Updating to Z-Way v4.1.4 fails
Post by otverber »
I have the same issue; however upgrade to 4.1.4 worked through the error messages.
ref: https://forum.z-wave.me/viewtopic.php?f=3417&t=36013
GokMasE
Post by GokMasE »
Good to hear you were able to get through. For me that is not the case, after that error msg there is nothing more happening at all.
Please use:
apt-get update && apt-get install z-way-server
GokMasE
Post by GokMasE »
Hiya and thanks for the reply.
I was eventually able to get v4.1.4 installed but not without some head scratching.
It was not enough with sudo apt-get update && apt-get install z-way-server to get it updated, there were complaints:
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
E: Unable to lock directory /var/lib/apt/lists/
W: Problem unlinking the file /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission denied)
W: Problem unlinking the file /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission denied)
It thus tried to separate the commands:
sudo apt-get update
sudo apt-get install z-way-server
The first command was carried out okay, but after the command to actually install z-way-server I got this message:
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
After following the instruction in that message, it was finally possible to get the update working with
Rudi56
Post by Rudi56 »
PoltoS wrote:
19 Aug 2024 14:20
Please use:
I have tryed this, but on "apt-get install z-way-server"
the response is
Reading package lists... Done
Building dependency tree
Reading state information... Done
z-way-server is already the newest version (4.1.3).
0 upgraded, 0 newly installed, 0 to remove and 407 not upgraded.
any way to upgrade to 4.1.4?
thanks in advance, Rudi
micky1500
Post by micky1500 »
This should work.
export BUILD=4.1.4; cd /tmp/ && wget https://storage.z-wave.me/z-way-server/z-way-${BUILD}_armhf.deb && sudo dpkg -i
