API use and log error
marco
Post by marco »
Hi dear,
I'm using a
Raspberry 4
Razberry 500 v2
Zway v3.0.4
Performing curl calls to set the temperature on Qubino thermostats, eg.
curl -u user:pwd "http://zway_ip:zway_port/ZAutomation/api/v1/devices/ZWayVDev_zway_81-0-67-1/command/exact?level=24"
everything seems to be ok and request is done correctly so the cli give me the answer
{"data":null,"code":200,"message":"200 OK","error":null}
And the thermostat is correctly set at the required temperature.
Redirecting the output on
&> /dev/null
everything as expected.
zway log tells me this:
[2024-11-13 07:58:55.250] [I] [zway] Node 81:0 CC ThermostatMode: Thermostat Mode 1 is not supported by device (modemask 0x9)
[2024-11-13 07:58:55.251] [I] [core] Notification: error (module): Error during perform command execution: Error: Invalid argument
[2024-11-13 07:58:55.258] [I] [core] Error: Invalid argument
    at Error (native)
    at t_vDev.(anonymous function).self.controller.devices.create.handler (automation/modules/ZWave/index.js:5758:62)
    at _.extend.performCommand (automation/classes/VirtualDevice.js:316:25)
    at ZAutomationAPIWebRequest._.extend.performVDevCommandFunc (automation/ZAutomationAPIProvider.js:442:51)
    at ZAutomationAPIWebRequest.handlerFunc (automation/ZAutomationAPIProvider.js:4241:31)
    at ZAutomationAPIWebRequest.ZAutomationWebRequest.handleRequest (automation/WebserverRequestRouter.js:263:35)
    at WebServer.document_root (automation/Webserver.js:36:11)
I double-checked, and ZWayVDev_zway_81-0-67-1, of course, exists.
This happens for all 13 thermostats I manage and seems to cause a temporary failure in server communication with UI
The log indications seem not useful. In index.js, at the suggested line, everything seems to be OK.
I also find regular situations in the other suggested files
At the moment I cannot update because the updater is unable to load the Firmware Update page
and I would prefer to be on site which is where I'm not.
Can anyone give me directions?
Marco
seattleneil
Re: API use and log error
Post by seattleneil »
Please update Z-Way to the newest version (4.1.4) and see if that fixes the problem. The version you are using (3.0.4) is almost 4 years old.
You can update Z-Way remotely from the command line. Run:
PKG=z-way-4.1.4_armhf.deb && wget -O /tmp/$PKG https://storage.z-wave.me/z-way-server/$PKG && sudo dpkg -i /tmp/$PKG
