Z-connector keeps failing with error box "Socket is gone"
same 2 errors as pvdspek
I see the same 2 errors as pvdspek ... not immediately, it might work for hours just fine. When the internet is unstable, then these errors come up. Instead of Z-Connector simply turning red while no internet is available + retrying every x minutes and then turning green again, I, too, have to click OK on the 2 errors + clicking connect once more. Not exactly a hands-off Z-Connector setup.
Please fix.
suggestion
as a suggestion: those errors should go into a log ... maybe even graphical log with time stamps ? Ideally this log would also hold info about when z-Connector managed to re-establish the connection. THANKS.
