Z-Way-Server log file
fez
Re: Z-Way-Server log file
Post by fez »
Strange indeed. My network didn't grow.
brusan
Post by brusan »
PoltoS wrote:2.3.0 have less logs than before (than 2.2.*). So it looks strange.... May be your network grew?
I would tend to disagree. Comparing the log-size of 2.3.0 to 2.2.* releases shows the log-size in 2.3.0 is at least ten times bigger. It might be that you have reduces the logging in the code base but in reality it is logging far more than previous releases (with the same log-level and same network size). Probably due to a problem in the new code running on a real system so when that is solved things probably will settle down.
Br/Brusan
I don't see more logs. May be you can share with us parts of logs that has grown?
fez
Post by fez »
I guess I haven't been watching carefully the (amount of) logs in the previous versions.
I think I can back up now your statement PoltoS (in comparison with 2.2.5).
I switched back the the 2.2.5 and that is also generating huge amount of logs, as I see more than the 2.3.0.
I didnt make a direct comparison though.
fez
Post by fez »
PoltoS, what other logs is Zway generating?
Where is event info showed in the webui stored?
in automation/storage/xxx
brusan
Post by brusan »
PoltoS wrote:I don't see more logs. May be you can share with us parts of logs that has grown?
The logs have been submitted to your support along with a lot of other info. I hope they will respond some day.
