Sending command to raspberry
Re: Sending command to raspberry
You probabaly have to write a module for that. You may have a look into Maros Kollar's blinds/window controller App
See detail on https://github.com/maros/Zway-BlindControl/
Markus96
Post by Markus96 »
Hey, i just tried if it works - it always says: Syntax error, unexpected identifier.
I followed your instrcutions, my code: system(sudo aircontrol -t blends_up)
you forgot "
system("sudo aircontrol -t blends_up")
Markus96
Post by Markus96 »
Thanks.
Next error-message:
Error during perform command execution: Error: This command is denied by policy.
pz1 mentioned this:
Finally you must set permission for ZWay to excute aircontrol. Therefore enter the full path + name of that command in file /opt/z-way-server/automation/.syscommands
Is this the problem?
I'm not sure what you mean with enter full path? What exactly do I need to set permission for zway to execute aircontrol?
Many thanks.
yes, this is the problem. You need to add to the file
Markus96
Post by Markus96 »
Thanks! That's it!
micky1500
Post by micky1500 »
Thanks guys. pz1 and PoltoS.
I was watching this thread :)
Now I can Control my Boiler for heating control.
Took over the remote thermostat via cheap 433Mhz Transmitter for a Worcester Boiler.
And it actually works...
sudo ./boiler 1111111111111101010101010101001110010101011010100110011010101010101010101001100101010101011111111111111111111111111111111111111111111111111 445 1 3
used examples from Wiring PI and Raspberry pi Forum. https://www.raspberrypi.org/forums/view ... 38#p499538
@micky1500 Thanks for sharing!
