Powered OFF then back ON. Same problem.
I went under MyIp:8083/expert but did not find the boot loader.
Where is it ? Could you tell me a bit more ?
PS : I'm also logged in as pi in ssh. I can take a look at the logs if needed.
Anyway, your help is warmly welcome !
Problem with Raspberry Pi 3 / Z-Wave board
- Z-Wave Support
Re: Problem with Raspberry Pi 3 / Z-Wave board
Please view ip:8083/expert/#/network/controller
If you not see, have your controller the current Version.
We think your Razberry is defect.
regards
Z-Wave Support
regards
Z-Wave Support
I've seen this happen multiple times now, with both the PI 3 and Pi2 models.
To fix this you need to pull the plug on Pi and then power it back up. The reset button on the Pi3 will also work, but just rebooting the Pi does nothing at all.
Did brianaker´s solution work ?
I had similar Problems.
You have to enter your licence key in the expert ui at first. Then do a reboot.
I'm having a very similar issue with a RPI3 and a Z-Wave. At this point I am trying to determine if I have a bad ZWave board or misconfigured software. Please let me know if you need additional information
I did the following:
- Installed 2016-11-25-raspbian-jessie.img on a SD card
- Installed Z-wave board on RPI3
- booted RPI3
- Configured Wifi connection on RPI3
- ran sudo apt-get update and sudo apt-get upgrade and then
- sudo reboot
- sudo apt-get install rpi-update
- sudo rpi-update
- sudo reboot
- wget -q -O - razberry.z-wave.me/install | sudo bash
- sudo shutdown
- remove power
-reapply power
The install process has a few errors amongst the console output including:
- ".. cannot access config/zddx/*.xml: No such file or directory"
- "diff: /etc/inittab: No such file or directory"
- "diff /tmp/zway_install_inittab: No such file or directory"
The last lines of z-way-server.log include:
[2016-12-30 12:48:03.541] [D] [zway] Opened device: /dev/ttyAMA0
[2016-12-30 12:48:03.541] [D] [zway] Worker thread successfully created
[2016-12-30 12:48:03.541] [D] [zway] Worker thread entry point
[2016-12-30 12:48:03.542] [zway] Adding job: Get controller info and support
ed function classes
[2016-12-30 12:48:03.552] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2016-12-30 12:48:03.754] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2016-12-30 12:48:03.754] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2016-12-30 12:48:03.956] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2016-12-30 12:48:03.956] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2016-12-30 12:48:04.158] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2016-12-30 12:48:05.246] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2016-12-30 12:48:05.246] [C] [zway] Get Serial API Capabilities returned zero.
[2016-12-30 12:48:05.246] [zway] Removing job: Get controller info and supported function classes
[2016-12-30 12:48:05.256] [D] [zway] Worker thread exit point
[2016-12-30 12:48:05.257] [D] [zway] Worker thread successfully finished
[2016-12-30 12:48:05.257] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2016-12-30 12:48:05.278] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
- booted RPI3
- sudo reboot
- sudo rpi-update
- sudo reboot
- sudo shutdown
- remove power
-reapply power
ed function classes
