Integration with Home Assistant
PerH
Re: Integration with Home Assistant
Post by PerH »
I see that lights on a dimmer comes in as a "number." entity, and I think they should be "light." instead?
This makes it difficult to use the lighting and dimmer cards..
Can't wait to get the updated plugin version so I can start porting the rest of my system (zigbee and 433) to HASS!
Fantini Dzherardo
Post by Fantini Dzherardo »
Chi condurrà il test, condividi le tue impressioni!
Fantini Dzherardo
Oh sorry. English :) If somebody will test it, share please
DerGrafausB
Post by DerGrafausB »
I'm using HA 2023.3.3 and zw 4.0.3.
I tried a lot of things, I can connect, but no device found.
ws://IP:port or just the IP:port
/apikey
User, Admin, User with devices.
But no device found.
Under HA Settings==>System==>logs nothing is written of z-wave.me.
Has anybody an idea?
michap
Post by michap »
strange... just have tested again with 2023.3.3 on second system.
Do you see in integrations the Z-Wave.Me element with your URL inside (like ws://192.168.x.y:8083) ?
What happen if you try to reload this integration? Something in log?
What devices you have enabled in Z-Way for this user?
Michael
We have noticed that if a blind device is present, no devices are exported. We are working on a fix.
The fix was merged into the HA sources. We hope it will become part of 2023.4 release. If not, then 2023.5.
https://github.com/home-assistant/core/pull/90233
https://github.com/Z-Wave-Me/zwave-me-w ... .1..v0.3.6
lindm
Post by lindm »
PerH wrote:
18 Sep 2022 23:47
@PoltoS
Is there a fix in sight for the problem that dimmers are incorrectly reported as "number entity" instead of "light entity"?
The Home Assistant HomeKit support does not pass "number" devices to iOS, so it is not possible to control dimmers with HomeKit.
(HomeKit from Home Assistant would be important right now where Zway's own HomeKit app doesn't work with the new HomeKit architecture that's been available since iOS 16.4.)
Yes, it is currently in work. I hope the fix will be ready next week and will be part of 2023.5 release.
We will check your report about iOS 16.4 not working with our HomeKit app
aivsss
Post by aivsss »
Hi! Today I updated the iOS to version 16.4 and I was able to add RaZberry to Homekit without any problems.
What exactly doesn't work on iOS 16.4? Adding a gateway? Displaying devices?
Please attache screenshot.
