http://127.0.0.1:8083/ZWaveAPI/Run/devi ... entScene=2
should be
EnerWave 7 button Scene Controller
Re: EnerWave 7 button Scene Controller
What Device Description Record are people using for the 7button Scene Controller?
It doesn't seem to be in the list.
Mike Yeager
Not using a description record. The new controller doesn't complete the interview either but it works just fine. I have noticed that it sends a series of binary numbers back to the Z-Way controller but it doesn't do anything with them. Maybe this will be addressed in the next version? Also, the commands above currently do not function to change the state of the controller but it's fine. I've found another way to accomplish what I wanted to do.
Were you able to get your original one to work? If so, does the new work work better? Since they both failed to complete the interview.
Mike Yeager
They both work and they both fail to complete the same part of the interview. I think that the controller isn't processing the data sent back from the interview request. I don't think it's a device problem. The scene controller works fine with Vera... Hopefully they'll fix this in a later version... Did you have questions about the operation of the device itself?
I don't think Vera is performing interview in terms of what z-way does, so the issue just might go unnoticed.Mike Yeager wrote:They both work and they both fail to complete the same part of the interview. I think that the controller isn't processing the data sent back from the interview request. I don't think it's a device problem. The scene controller works fine with Vera... Hopefully they'll fix this in a later version...
Can you please tell which command classes are not passing interview, and provide an entire log (as attachment)?
Yes, I have questions about how you assign buttons to scenes. How do you do it?Mike Yeager wrote:Did you have questions about the operation of the device itself?
Mike Yeager
I'll handle both of these requests when I get home in the morning.
Mike Yeager
Ok. Attached is the portion of the log that relates to the failure to complete the interview. If I'm not mistaken, there is data coming back to the controller, it just doesn't appear to be being processed. The only part of the interview that doesn't complete is VERSION.
Here it is in plain text until I figure out why the file won't attach...
[2014-07-30 13:15:54.775] Executing script: zway.devices[15].instances[0].commandClasses[134].Interview()
[2014-07-30 13:15:54.780] Adding job: SceneControllerConf Version Get
[2014-07-30 13:15:54.781] Adding job: ManufacturerSpecific Version Get
[2014-07-30 13:15:54.782] Adding job: Association Version Get
[2014-07-30 13:15:54.783] Adding job: Version Version Get
[2014-07-30 13:15:54.791] SENDING (cb 0xf1): ( 01 0A 00 13 0F 03 86 13 2D 25 F1 86 )
[2014-07-30 13:15:54.802] RECEIVED ACK
[2014-07-30 13:15:54.813] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-07-30 13:15:54.814] SENT ACK
[2014-07-30 13:15:54.815] Delivered to Z-Wave stack
[2014-07-30 13:15:54.837] RECEIVED: ( 01 05 00 13 F1 00 18 )
[2014-07-30 13:15:54.838] SENT ACK
[2014-07-30 13:15:54.838] Job 0x13 (SceneControllerConf Version Get): Delivered
[2014-07-30 13:15:54.839] SETDATA devices.15.data.lastPacketInfo.delivered = True
[2014-07-30 13:15:54.840] SETDATA devices.15.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-07-30 13:15:54.840] SETDATA devices.15.data.lastPacketInfo.deliveryTime = 23 (0x00000017)
[2014-07-30 13:15:54.841] SETDATA devices.15.data.lastPacketInfo = **********
[2014-07-30 13:15:54.841] SendData Response with callback 0xf1 received: received by recipient
[2014-07-30 13:15:54.842] SETDATA devices.15.data.lastSend = 26832452 (0x01996e44)
[2014-07-30 13:15:54.843] Job 0x13 (SceneControllerConf Version Get): success
[2014-07-30 13:15:54.844] Removing job: SceneControllerConf Version Get
[2014-07-30 13:15:54.913] SENDING (cb 0xf2): ( 01 0A 00 13 0F 03 86 13 72 25 F2 DA )
[2014-07-30 13:15:54.924] RECEIVED ACK
[2014-07-30 13:15:54.935] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-07-30 13:15:54.936] SENT ACK
[2014-07-30 13:15:54.937] Delivered to Z-Wave stack
[2014-07-30 13:15:54.959] RECEIVED: ( 01 05 00 13 F2 00 1B )
[2014-07-30 13:15:54.960] SENT ACK
[2014-07-30 13:15:54.961] Job 0x13 (ManufacturerSpecific Version Get): Delivered
[2014-07-30 13:15:54.961] SETDATA devices.15.data.lastPacketInfo.delivered = True
[2014-07-30 13:15:54.962] SETDATA devices.15.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-07-30 13:15:54.963] SETDATA devices.15.data.lastPacketInfo.deliveryTime = 24 (0x00000018)
[2014-07-30 13:15:54.964] SETDATA devices.15.data.lastPacketInfo = **********
[2014-07-30 13:15:54.964] SendData Response with callback 0xf2 received: received by recipient
[2014-07-30 13:15:54.965] SETDATA devices.15.data.lastSend = 26832462 (0x01996e4e)
[2014-07-30 13:15:54.966] Job 0x13 (ManufacturerSpecific Version Get): success
[2014-07-30 13:15:54.966] Removing job: ManufacturerSpecific Version Get
[2014-07-30 13:15:55.036] SENDING (cb 0xf3): ( 01 0A 00 13 0F 03 86 13 85 25 F3 2C )
[2014-07-30 13:15:55.047] RECEIVED ACK
[2014-07-30 13:15:55.058] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-07-30 13:15:55.059] SENT ACK
[2014-07-30 13:15:55.059] Delivered to Z-Wave stack
[2014-07-30 13:15:55.082] RECEIVED: ( 01 05 00 13 F3 00 1A )
[2014-07-30 13:15:55.082] SENT ACK
[2014-07-30 13:15:55.083] Job 0x13 (Association Version Get): Delivered
[2014-07-30 13:15:55.084] SETDATA devices.15.data.lastPacketInfo.delivered = True
[2014-07-30 13:15:55.085] SETDATA devices.15.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-07-30 13:15:55.085] SETDATA devices.15.data.lastPacketInfo.deliveryTime = 24 (0x00000018)
[2014-07-30 13:15:55.086] SETDATA devices.15.data.lastPacketInfo = **********
[2014-07-30 13:15:55.087] SendData Response with callback 0xf3 received: received by recipient
[2014-07-30 13:15:55.088] SETDATA devices.15.data.lastSend = 26832472 (0x01996e58)
[2014-07-30 13:15:55.089] Job 0x13 (Association Version Get): success
[2014-07-30 13:15:55.089] Removing job: Association Version Get
[2014-07-30 13:15:55.159] SENDING (cb 0xf4): ( 01 0A 00 13 0F 03 86 13 86 25 F4 28 )
[2014-07-30 13:15:55.170] RECEIVED ACK
[2014-07-30 13:15:55.181] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-07-30 13:15:55.182] SENT ACK
[2014-07-30 13:15:55.182] Delivered to Z-Wave stack
[2014-07-30 13:15:55.204] RECEIVED: ( 01 05 00 13 F4 00 1D )
[2014-07-30 13:15:55.205] SENT ACK
[2014-07-30 13:15:55.206] Job 0x13 (Version Version Get): Delivered
[2014-07-30 13:15:55.207] SETDATA devices.15.data.lastPacketInfo.delivered = True
[2014-07-30 13:15:55.207] SETDATA devices.15.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-07-30 13:15:55.208] SETDATA devices.15.data.lastPacketInfo.deliveryTime = 23 (0x00000017)
[2014-07-30 13:15:55.209] SETDATA devices.15.data.lastPacketInfo = **********
[2014-07-30 13:15:55.209] SendData Response with callback 0xf4 received: received by recipient
[2014-07-30 13:15:55.210] SETDATA devices.15.data.lastSend = 26832482 (0x01996e62)
[2014-07-30 13:15:55.211] Job 0x13 (Version Version Get): success
[2014-07-30 13:15:55.211] Removing job: Version Version Get
FWIW: Usualy if a file does not properly attach, there is a red error message at the very top of your edit window. The file should not be bigger than some 500K. Some extensions (even .txt) are not allowed. Zips do pass as long as they are smaller than 500K.Mike Yeager wrote: Here it is in plain text until I figure out why the file won't attach...
