HomeKit gate all devices show “no response”
mcpat
Re: HomeKit gate all devices show “no response”
Post by mcpat »
VickyPope wrote: ↑
27 Jul 2023 11:36
you can try the following steps:
Check device connections and make sure they are working and connected to the same Wi-Fi network as the HomeKit gateway.
Restart the HomeKit gateway to try to fix the connection issue.
Ensure that devices and related software are updated to the latest to optimize compatibility.
Verify that the devices you want to connect are officially supported by HomeKit and compatible with the version of zway you are using.
Check network settings and make sure your iOS and HomeKit gateway are connecting to the same local network.
Turn off any firewalls or security software that may be blocking communication between iOS and the HomeKit gateway.
If that fails, try configuring HomeKit again and start the reset process from scratch.
Look up the documentation or join the zway user community to find solutions from experienced people.
It was working all the time. Updating to newest version didn’t help. Also rebooting not. All devices are in the same network. So the only way is using HA…
Topas
Post by Topas »
I deleted the whole Z WAVE ME Server and switched to HA.
