ControlThink USB Stick
schwarzenbergf
Post by schwarzenbergf »
I use ControlThink USB stick. There is no serial interface emulation (I have no COM Port to access the stick).
Other applications like ZWave Commander work fine with it.
Any ideas how to work with z-connector?
Thanks,
Frank
ControlThink uses completely another API
The API they use is not compatible at all with Zensys Serial API we use. We do not support ControlThink API.Unfortunately you have yo switch to one of the supported devices. These manufacturers are compatible:Z-Wave.MeAeonLabsTricklestarSeluxitOr get firmware upgrade from ControlThink to update to standard Zensys Serial API firmware. Not sure if this exists.
