Installing on DD-wrt
morten.ls
Post by morten.ls »
I have been trying to install my z-wave.me z-stick on my asus n16 running dd-wrt.
I have installed all the ipk files from http://en.z-wave.me/content/compiling-z ... eir-clones
The guid says then that i further should copy the certificate and make the start up script. But i can't see that the usb gets mounted. I have also tried loading the modules, but nothing seem to work, i only get the following messages.
usb 2-1: new full speed USB device using ohci_hcd and address 8
usb 2-1: configuration #1 chosen from 1 choice
Any help would be appreciated.
You need to load pl2303 driver
You need to load the following driver: pl2303.o (Prolific 2303 Single Port Serial Driver)Should be located in package kmod-usb-serial-pl2303 -- Kernel Support for Prolific PL2303 USB-to-Serial converters available using ipkg
morten.ls
I have installed it, but i
Post by morten.ls »
I have installed it, but i got a warning...
root@DD-WRT:~# ipkg install /jffs/kmod-usb-serial-pl2303_2.4.30-brcm-5_mipsel.ip
k
ipkg_depends: Warning: kernel mentioned in dependency but no package found in /jffs/usr/lib/ipkg/lists
Unpacking kmod-usb-serial-pl2303...Done.
Configuring kmod-usb-serial-pl2303...Done.
Now when i plug in the usb stick it causes the router to reboot, is this normal?
Be sure to install correct driver version
The warning is about absense of kernel package in the list of packages. This can probably be ignored.The stick should not cause router to reboot. This is probably caused by some problems in your DD-WRT build or incompatibilities of kernel version with module version of PL2303 you installed.Be sure to run ipkg update before installing the driver.
