Eventghost dimming script
Mousemke
Post by Mousemke »
I've been searching everywhere for a way to dim lights triggered through eventghost and zsend finally did the trick.
I don't quite understand if it's possible to write new scripts. How would I set different dim settings or use relative increments?
ZSend can only set a predefined dimming level
ZSend was written especially for Skil / ATE bvba to run on tablet and portable PC designed for persons with limitations. It was made as simple as possible to be very intuitive and fit into existent solution. Unfotunately you can not write your own scripts using ZSent.
Mousemke
suggestions?
Post by Mousemke »
i realize it wasnt built for it, but it worked in a pinch. any suggestions on a way to set a lamp dim level from a pc?
Use our Z-Cloud solution
It requires Internet connection, but allows you to easily execute commands from any software like EventGhost. Refer to the description of Z-Cloud/Z-Way API to get more info.We understand it is not a standalone program as you wanted, but it works and it is for free.
