z-wave.me motor control - Reaction on opposite Button
Posted: 09 May 2012 23:00
With parameter 8 set to 0 (the default) the reaction when hitting
the opposite button when motor is moving is set to "stop" - and
this works well.
But when I send an Basic on/off Command, it stops and moves
in the reverse direction. Therefore, if I associate the motor control
to a (e.g. zwave.me) wall controller, hitting the the opposite button on the
wall controller "stops and start moving into the reverse direction",
regardless the settings on parameter 8.
Is there another parameter to change this behavior - otherwise i would think
it a bug.
The original DÜWI Firmware stops on both the local buttons and on on/off Commands
if the motor is moving.
Bernhard
this works well.
it a bug.
Bernhard
