For some reason I cannot see anymore 8 of my devices (most of them dimmer 507900 from Merten) under 'Aktoren' (sorry, I have the German localization, don't know what is there in English, maybe 'Actors'?).
They are visible in 'Device Status' and also in the 'Device Configuration' tab. Even in 'Zones' they are visible and usable.
These are all devices with addresses less than 11, or with other words, the list under '.Actors' starts with address 11.
What can I do to get them back under 'Aktoren' ?
Thanks,
Frank
Do not see devices under 'Aktoren' which are availabel under 'Device Status'
schwarzenbergf
We hve updated Z-Cloud recently
Have you restarted your instance? Reconnet Z-Connector and reload the page in browser after srver is restarted. This should help.
As we see in our code, the
As we see in our code, the only reason not to see the device in this list is due to some other instance announced by the device. With Merten devices that uses MultiInstance in their s/w it might happen that you have configured to send some MultiInstance commands to Z-Cloud. In such case it will think this device to have multiple instances and will not show instance 0, while all other instances are empty. (So, nothing is shown).This is certainly a logical gap in our Z-Way/Z-Cloud - we have never thought about this case. The only idea is to explicitely delete the instance by running in JS debug console:runCmd('devices[XXX].instances.Delete(NNN)'), where XXX is device Id, NNN is the instance Id not equal to 0. To get it browse the object ZWaveAPIData.devices[XXX].instances.Another easy idea is to re-interview the device. Both will solve the problem only for a while.We will fix this bug in future. Thank you for reporting your problem.
schwarzenbergf
re-interview worked
Thanks, re-interview worked for now. At least I know a work-around now.
Best regards,
Frank
Best regards,
Frank
