I keep haveing a problem where Z-connector disconnects with the message 'socket has gone' or something similar, it doesnt autoamtcally reconnect but if i hit the connect button it starts working again. What is causing this?
This is now the remaining major cause of unreliability.
Z-Connector Loses socket
schwarzenbergf
I see this too. If my
I see this too. If my internet connection drops down for some reason, this happens.
OK, this can happen, but there should be an automatic reconnect.
At the moment I have to log-on to the server and reconnect manually. Not so good.
I figured it was something
I figured it was something todo with my internet connection which is over WIFI, it should reconnect though as ive turned that option on, I agree not good. I appreciate this software is free to use, but also the downside is we are free bug-testers for the developers and that irritates the hell out of me because I just want it to work.
I tested LightwaveRF last night, worked perfectly from the remote control and comes with built in climate shchedules, downside is build quality isnt as good and its a bit noisy.
Thanks for the bug report. We will fix this soon
