Change Scene error
Change Scene error
Under Automation/Zones I changed a scene that is bound to a Climate Scedule. On that change the interface gave the following error message "Scene activation: Forbidden, Exception activating climate schedule 1 (unsupported operand type(s) for +: 'int' and 'instance')". Changing Climate schedule does not give an error this time, but has also done before. I vaguely remember having asked this before, but I could not find that post again. So my apologies for possibly double questions.
Pieter
Could you please do it again and show us the log?
Current code for Climate Schedules was improved to make it support new devices. May be a bug was introduced with this improvement? We will fix it in a very short time after we see your log.
Here is the log
Here is the log.
2012-06-08 10:33:30,292 Except.CRITICAL Error handling web request: /ZWaveAPI/Data/1339144397
2012-06-08 10:33:30,292 Except.CRITICAL TypeError: is not JSON serializable
2012-06-08 10:33:30,291 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 344, in default
2012-06-08 10:33:30,291 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 323, in _iterencode_default
2012-06-08 10:33:30,291 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 317, in _iterencode
2012-06-08 10:33:30,291 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 275, in _iterencode_dict
2012-06-08 10:33:30,291 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 309, in _iterencode
2012-06-08 10:33:30,290 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 309, in _iterencode
2012-06-08 10:33:30,290 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 275, in _iterencode_dict
2012-06-08 10:33:30,290 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 367, in encode
2012-06-08 10:33:30,290 Except.CRITICAL File "/var/pyzw/pyzw/WebServer.py", line 170, in do_POST
2012-06-08 10:33:30,288 Except.CRITICAL Traceback (most recent call last):
2012-06-08 10:33:28,248 Except.CRITICAL Error handling web request: /ZWaveAPI/Data/1339144397
2012-06-08 10:33:28,248 Except.CRITICAL TypeError: is not JSON serializable
2012-06-08 10:33:28,248 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 344, in default
2012-06-08 10:33:28,247 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 323, in _iterencode_default
2012-06-08 10:33:28,247 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 317, in _iterencode
2012-06-08 10:33:28,246 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 275, in _iterencode_dict
2012-06-08 10:33:28,246 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 309, in _iterencode
2012-06-08 10:33:28,245 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 367, in encode
2012-06-08 10:33:28,245 Except.CRITICAL File "/var/pyzw/pyzw/WebServer.py", line 170, in do_POST
2012-06-08 10:33:28,243 Except.CRITICAL Traceback (most recent call last):
2012-06-08 10:33:26,228 Except.CRITICAL Error handling web request: /ZWaveAPI/Data/1339144397
2012-06-08 10:33:26,228 Except.CRITICAL TypeError: is not JSON serializable
2012-06-08 10:33:26,228 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 344, in default
2012-06-08 10:33:26,227 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 323, in _iterencode_default
2012-06-08 10:33:26,227 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 317, in _iterencode
2012-06-08 10:33:26,227 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 275, in _iterencode_dict
2012-06-08 10:33:26,227 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 309, in _iterencode
2012-06-08 10:33:26,226 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 275, in _iterencode_dict
2012-06-08 10:33:26,226 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 309, in _iterencode
2012-06-08 10:33:26,226 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 367, in encode
2012-06-08 10:33:26,225 Except.CRITICAL File "/var/pyzw/pyzw/WebServer.py", line 170, in do_POST
2012-06-08 10:33:26,224 Except.CRITICAL Traceback (most recent call last):
2012-06-08 10:33:24,241 Except.CRITICAL Error handling web request: /ZWaveAPI/Data/1339144397
2012-06-08 10:33:24,240 Except.CRITICAL TypeError: is not JSON serializable
2012-06-08 10:33:24,240 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 344, in default
2012-06-08 10:33:24,240 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 323, in _iterencode_default
2012-06-08 10:33:24,240 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 317, in _iterencode
2012-06-08 10:33:24,240 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 275, in _iterencode_dict
2012-06-08 10:33:24,239 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 309, in _iterencode
2012-06-08 10:33:24,239 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 275, in _iterencode_dict
2012-06-08 10:33:24,239 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 367, in encode
2012-06-08 10:33:24,238 Except.CRITICAL File "/var/pyzw/pyzw/WebServer.py", line 170, in do_POST
2012-06-08 10:33:24,237 Except.CRITICAL Traceback (most recent call last):
2012-06-08 10:33:22,253 Except.CRITICAL Error handling web request: /ZWaveAPI/Data/1339144397
2012-06-08 10:33:22,253 Except.CRITICAL TypeError: is not JSON serializable
2012-06-08 10:33:22,252 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 344, in default
2012-06-08 10:33:22,252 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 323, in _iterencode_default
2012-06-08 10:33:22,252 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 317, in _iterencode
2012-06-08 10:33:22,252 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 275, in _iterencode_dict
2012-06-08 10:33:22,252 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 309, in _iterencode
2012-06-08 10:33:22,251 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 275, in _iterencode_dict
2012-06-08 10:33:22,251 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 309, in _iterencode
2012-06-08 10:33:22,251 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 367, in encode
2012-06-08 10:33:22,251 Except.CRITICAL File "/var/pyzw/pyzw/WebServer.py", line 170, in do_POST
2012-06-08 10:33:22,249 Except.CRITICAL Traceback (most recent call last):
2012-06-08 10:33:20,238 Except.CRITICAL Error handling web request: /ZWaveAPI/Data/1339144397
2012-06-08 10:33:20,238 Except.CRITICAL TypeError: is not JSON serializable
2012-06-08 10:33:20,237 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 344, in default
2012-06-08 10:33:20,237 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 323, in _iterencode_default
2012-06-08 10:33:20,237 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 317, in _iterencode
2012-06-08 10:33:20,237 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 275, in _iterencode_dict
2012-06-08 10:33:20,237 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 309, in _iterencode
2012-06-08 10:33:20,236 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 309, in _iterencode
2012-06-08 10:33:20,236 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 275, in _iterencode_dict
2012-06-08 10:33:20,235 Except.CRITICAL File "/usr/lib/python2.6/json/encoder.py", line 367, in encode
2012-06-08 10:33:20,234 Except.CRITICAL File "/var/pyzw/pyzw/WebServer.py", line 170, in do_POST
2012-06-08 10:33:20,232 Except.CRITICAL Traceback (most recent call last):
2012-06-08 10:33:18,301 Rules.INFO Enabling Climate Schedule on 4:0
2012-06-08 10:33:01,196 Rules.INFO Event: from 3:0 to 1:0, Report, value: [37, 255]
2012-06-08 10:33:01,143 Z-Wave.INFO Send to device 3, instance 0, switch binary get: Delivered
2012-06-08 10:32:01,206 Rules.INFO Event: from 3:0 to 1:0, Report, value: [37, 255]
2012-06-08 10:32:01,143 Z-Wave.INFO Send to device 3, instance 0, switch binary get: Delivered
2012-06-08 10:31:57,013 Z-Wave.INFO Send to device 4, instance 0, wakeup no more information: Not delivered to recipient
2012-06-08 10:31:56,746 Z-Wave.INFO Send to device 4, instance 0, Multi Command with 2 encapsulated commands: Send to device 4, instance 0, clock report, Send to device 4, instance 0, Schedule Change Report: Callback received - transfered to encapsulated jobs
2012-06-08 10:31:56,746 Z-Wave.INFO Send to device 4, instance 0, Schedule Change Report: Delivered
the error is still there
Well the error is still there. I am running presently (3 weeks steady) z-agent that I have compiled for Synology DS212+
Seems to be fixed now
Please try to reconnect and test the issue.
Error has gone now
Indeed, error has gone now. Thanks.
Thanks for the report!
We are trying to do our best for our clients
