Weekdays one day off in schedules
gpostuma
Post by gpostuma »
When writing a schedule that contains a weekday things don't work as I expect.
It seems that the weekday is one day off, for example if today is Friday the schedule does not work when I put in as weekday Friday, but it does work if I enter Saturday.
Suppose today is Friday:
A schedule that only uses Friday fails.
Also creating a schedule that uses all days except the next day (Saturday) fails.
As mentioned above, a schedule that uses only Saturday works.
This behaviour is consistent for every weekday.
A detail that is also present: when entering a weekday, the initial value is always Tuesday, while Sunday or Monday would be more logical.
Is this a known issue, or can there be something wrong in the server/software?
Thank you for your bug report.
There was a problem in the UI. On the server side everything was OK. Not the problem is fixed (will be updated in 30 minutes) and you can check it.
gpostuma
Solved!
Post by gpostuma »
Thanks for your quick update. Schedules work as expected again.
