Agent Loop Problem on Raspberrypi
albersag
Post by albersag »
Hi
I have compiled and seems to work fine, but i get a loop problem an disconected from server.
He it is a portion of log
root@raspberrypi:/home/pi/Z-Connector/Unix# cat debug
Opening device...
[D] Configuring device...
[D] Creating a socket...
[D] Enabling keep-alives on the socket...
Connecting to server...
[D] Initialising OpenSSL environment...
[D] Allocating SSL context...
[D] Loading personal certificate...
[D] Loading personal certificate key...
[D] Loading CA certificate...
[D] Setting verification mode...
Establishing SSL connection...
[D] Allocating SSL session...
[D] Assigning socket...
Performing SSL handshake...
[D] Initialising SSL state...
[D] Sending handshake...
[D] Server has closed the SSL connection
[D] Shutting down SSL session...
[D] Freeing SSL session...
Loop started
[D] socket has data
[D] 5 bytes:
[D] 01 03 00 07 FB
[D] socket has data
[D] 5 bytes:
[D] 01 03 00 07 FB
[D] socket has data
[D] 5 bytes:
[D] 01 03 00 07 FB
[D] Server has closed the connection
[E] Socket has gone
Loop ended
What coult be wrong? Any idea what to check?
I could open /dev/ttyUSB0 and seems to be recognised without problems
dmesg output:
[ 3269.930924] usb 1-1.2.2: new full-speed USB device number 9 using dwc_otg
[ 3270.032499] usb 1-1.2.2: New USB device found, idVendor=067b, idProduct=2303
[ 3270.032528] usb 1-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3270.032545] usb 1-1.2.2: Product: USB-Serial Controller D
[ 3270.032559] usb 1-1.2.2: Manufacturer: Prolific Technology Inc.
[ 3270.033657] pl2303 1-1.2.2:1.0: pl2303 converter detected
[ 3270.037573] usb 1-1.2.2: pl2303 converter now attached to ttyUSB0
lsusb -v
Bus 001 Device 009: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x067b Prolific Technology, Inc.
idProduct 0x2303 PL2303 Serial Port
bcdDevice 4.00
iManufacturer 1 Prolific Technology Inc.
iProduct 2 USB-Serial Controller D
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 39
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x000a 1x 10 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0000
(Bus Powered)
im using a zwave me USB connector
According to the log the
According to the log the stick does not repy to init commands.
Make sure the port is not used by some other program.
Also try the stick on another port.
Are you sure the stck works on another Linux machine?
Also try to unload pl2303 module and load it back - sometimes it helps:
modprobe -r pl2303
modprobe pl2303
Check this: https://bugs.launchpad.net/ubuntu/+sour ... bug/661321
albersag
I have tried same device on
Post by albersag »
I have tried same device on Windows and get same trouble. So as you mention it seems a problem connecting to stick? Is there any way to check if its working properly sending som commands?
Did it worked once? May be it
Did it worked once? May be it is boken/damaged? Exchange it in your shop.
albersag
It never worked. No under
Post by albersag »
It never worked. No under windows no under linux
It seems to be damaged.
