Linux newbie can't install z-agent
Posted: 15 Jan 2013 14:02
by t2tonesimone
Tried what little I could find to install Z-agent after downloading it using some small bits of advice from forum. Just wondered if there is a linux (Ubuntu) installation guide somewhere as I am really struggling.
I managed the sudo apt-get lidg-dev or whatever it was and can navigate to the unix folder but it says there is no such command as make. How do I compile it?
thanks
You need to install development tools
Something like this should do the job: sudo apt-get install make gcc libargtable2-dev libssl-dev
./Run_Z-Agent.sh...
by eligv
./Run_Z-Agent.sh...
E] opening device
failed to open device: permission denied
E] opening device
E] opening device
failed to open device: permission denied...
Try tu run under superuser
Try to run under superuser (root): sudo ./Run_Z-Agent.sh
This can be solved by correct permissions on port or adding youself to the group owning the ttyUSBx device.
Right! With da superuser
by eligv
Right! With da superuser permissions and starts the loop.
Thank you very much.
