Select device description record
mcfanda
Post by mcfanda »
Hi
in zcloud, when I try to change the device description record, I can select the correct device specs from the list, but when I click "select" nothing happen. Any help?
mcfanda
When I reset all the
Post by mcfanda »
When I reset all the configuration the problem went away
Re: Select device description record
The device description list is becoming rather messy.
  1. If I understand correctly, it is sorted on how well the description should fit the selected device. That does not always happen. An optional alphabetic sort might help in finding the correct device in the ever growing list.
  2. The second problem I have are the unnamed records represented by the xml file name only. Those do not make much sense.
  3. My third problem is in possible duplicates. For example for the Fibaro Universal Sensor there are three entries, where the names do not reflect any differences in their content. Which must I choose when?
If I can help somewhere to clean this up, please contact me.
Pieter
To clean it up you need to have all these devices and their different variants... In new Expert UI we will change the select box to sort in order of priority (as now) and make a filter to allow typing in names.
If you really want to dive into ZDDX, please contact CP, he can certainly give you access to it.
