Basic command
delvedi
Basic command
Post by delvedi »
tried to play around with an AN158 everspring power switch. Seems to work when using
http://mediaserver:8083/JS/Run/zway.dev ... t%28255%29;
but when using
system returned "Uncaught TypeError: Cannot call method 'Set' of undefined". Why is the "Basic" command not recognized for this switch?
The log shows
[2013-04-23 19:19:27.928] SENT ACK
[2013-04-23 19:19:27.930] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-04-23 19:19:27.932] SETDATA devices.2.instances.0.commandClasses.50.data.2
.val = 9.000000
[2013-04-23 19:19:27.933] SETDATA devices.2.instances.0.commandClasses.50.data.2
.delta = 0 (0x00000000)
[2013-04-23 19:19:27.936] SETDATA devices.2.instances.0.commandClasses.50.data.2
.ratetype = 1 (0x00000001)
[2013-04-23 19:19:27.937] SETDATA devices.2.instances.0.commandClasses.50.data.2
= Empty
try ...commandClasses.Basic
try ...commandClasses.Basic.Set(...)
You certainly use older version of RaZberry. Please update (run the same install script again) and you will be able to omit commandClasses word
delvedi
Post by delvedi »
Tried with latest version and problem is gone.
Thanks for your help
