Z-way freezes on Map
moustique0808
Post by moustique0808 »
I am new on this forum and NewComer of Zwave.
I have installed successfully the zwave board on my raspberry, then installed everything to access correctly z-way. One sensor (door) is successfully included as well.
Now, in the Map, when I left-click on the appartment and add a new child, I enter a name of the new child then on the bottom page it asks me to draw the new area. But it is impossible to draw anything as the windows is freezed. Clicking on other link doesn't work and I have to re-load again the page to have "hand" on it again. Does someone knows what is my problem and advise me. Thanks.
We have fixed some bugs in
We have fixed some bugs in the UI. Please update and try again. If not, we will need the output from Chrome log console.
moustique0808
Thanks for your feedback.
Thanks for your feedback. Could you inform me the process to update it? Is there any script or command that i have to execute? Thanks.
Just run the same script as
Just run the same script as you used for installation. This is about RaZberry. Are you also referring to RaZberry?
