Missing "Automation" Tab on Z-way software?
ma212
Post by ma212 »
I recently bought some z-wave stuff and already installed the z-wave software on my razberry.
I also successfully set the inclusion of some devices but I am stil struggling with the documentation and the configuration.
E.g. I do not have any "Automation" tab visible on the z-way software but the documentation shows this tab for configuration.
Any idea?
Regards
whecker
Missing "Automation" Tab in z-Way software
Post by whecker »
I have the same problem. the automation tab is also missing. When I open the tab "Devices Configuration" and mark my Razberry controller, an error appears saying that the home automation is not implemented.
How can i complete this home automation?
You can do your own
You can do your own JavaScript home automation or wait for a beautiful UI that is work in progress.
src
Any updates/schedules?
Post by src »
..on home automation UI?
If I do my own automation, what the start point for that? Any guides/how-tos to start from?
Some drafts are in the new 1
Some drafts are in the new 1.4 version. See release info
LinuxDEV
Re: Missing
Post by LinuxDEV »
I have the same problem ..i need Automation tab .Please help , i install the latest version and now i dont see the config.json intro /automation folder, i mean Automation into the /expert/ area
Need help please,
Regards
Re: Missing
There will never be automation in /expert (Blue) UI. You need to go in Home Automation UI. There you can make your home automarion. Latest release candidate version shows how it will be.
LinuxDEV
Re: Missing
Post by LinuxDEV »
Ok, please tell me how can i do this in this case becouse i cannot add nothing in Home Automatization UI at the web page,or please give me an script or files t do that
Thank you in advance,
Re: Missing
Please use v1.7.0-rc3 and go into Home Automation UI
LinuxDEV
Re: Missing
Post by LinuxDEV »
Ok, i do this, and after i go into Automation UI and create a room or anything else, but nothing compares into web page,
Please help with this
