python scripts in rules
Posted: 11 Sep 2013 18:17
I was curious as to how the rules engine works in handling a script.
I noticed that the rules engine for event checking is rather limited. The drop down for event checks appears static, as opposed to changing based on which device is selected. So if I wanted to trigger a rule based on a change of a specific command I assume I'd have to use a python script to do it?
Is that a correct assumption? and if so , I'm a bit unclear on how because I'm unsure of when a rule script would be evaluated. Any information anyone could provide to help clear this up would be greatly appreciated.
