Every scenes are working well when activated manually, but all schedules stop working and the scenes did not start automatically.
I hope someone can help on this.
Thank you
Best regards,
Rui Robert
SOLVED: Schedules are not working on Z-Cloud
Dear Robert, Z-Cloud is not
Dear Robert, Z-Cloud is not supported anymore. You can still use it for free, but it is not maintained.
Dear PoltoS,
Dear PoltoS,
thank you for your answer.
I know that Z-Clous is no longer maintained, but as schedules were usually working and stop working for no apparent reason, I thought it could be some minor issue on Z-cloud environment.
BTW, I have USB stick Z-Wave.Me ZW0301, with SDK version 5.03, is it compatible with Z-Way, or could have some firmware upgrade so it become compatible?
Thank you for your help
Best Regards,
Rui Robert
Best Regards,
Rui Robert
No, it is not. We need SDK 4
No, it is not. We need SDK 4.54+. And the one you have has no f/w update yet.
Thank you for your answer.
Last question about this matter: The schedules are handled on Z-Way server or on Z-wave controller (USB Stick)?
SOLVED:
With debug log it is possible to see a CRITICAL error on Rules.xml file. After a backup it is possible to open a the zipped file and then open the rules.xml and look for the error. It was a problem on scene definition. After correct that problem the schedules are working again. Thank you for your possible help.
