I've hit a wall, and please be gentle, I'm a Z-wave newbie! I've done a lot of home automation in the past though, so I do think I have a good general idea of things.
I'm using a RaZberry and I've successfully added a Fibaro Wall Plug to my network. But when I try to add a Fibaro Wall Dimmer Z-way just times out, no matter what I try.
I've tried by pressing the wall button three times in a row, I've tried pressing the B button, and I've tried to exclude the dimmer and retried adding it. Nothing works.
The distance is only three metres from my RaZberry, so that really shouldn't be the problem.
The dimmer works with the wall switch button, I can switch it on/off/dim without a problem.
Does anyone has any ideas??
BR,
Jens
Problem adding a Fibaro Wall Dimmer to Razberry
Problem solved!
Turns out I just wasn't quick enough pressing the B-button three times! I read in another forum you need to be really really fast, so I tried it a couple of times and now it works.
