failed to perform handshake ssl
Posted: 20 Nov 2013 13:40
by hatipoglu79@hotmail.com
First time im trying Z-StickC and AeonLabs Stick to connect Z-cloud.
Cert path is correct,
Run as Admin,
No firewall,
but i see "failed to perform handshake ssl:null"
If i dont select "use secure connection" box it connects (loop started) but cant see web gui because cert is not trusted and;
If i continue;
Your Z-Cloud instance is not running
Your Z-Cloud web interface is only active if your Z-Connector on your local PC is working and has a connection to the online part of Z-Cloud server.
Please make sure that
•your Z-Wave USB Stick is connected to a PC
•the Z-Connector is running on your PC with the correct IP address and port of the Z-Cloud server and the correct ssl credentials (certificates). If you run the Unix version you may check the console output of the Z-Connector to see if the connector is running. The windows version will indicate a working connection in the tray.
Any idea?
same problem today
by drdh
I think it's a server problem
Problem still exist...
Does Z-box hardware use same platform?
Any other application that Works with Z-Sticks?
SSL Handshake problem
by drdh
Problem still exists here too.
i'm also searching for another application. I tried Homeseer but it's not so easy to use for novice in zwave and it's expensive. Moreover i didn't have enough time with the trial version to understand how it works.
Another is openremote but difficult to install. Hatipoglu, let me know if you find something.
incontrol sofware
http://store.incontrolzwave.com/incontr ... e-download
its free for 6 mounths and Works! (except ir devices)
good really good!
Z-Box uses newer s/w. Note
Z-Box uses newer s/w. Note that Z-Cloud is not supported anymore (for quite some time), so do not expect it to work perfectly.
